Billsy
x 9
Unread post by Billsy »
Hi Marc
I'm wondering if this part is available on it's own or is it part of the full side panel?
VR3**************[VIN obfuscated, can be read by forum staff]
x 6946
Item (2)?
Front Wing Inner Frame (Left), part: 1646180980, £330.82
(1) Post Stiffener (Left), part: 1646182980, £208.04
Billsy
x 9
It's 13 on the top pic, 3 on the bottom one
x 6946
Ok, so (13) & (3) is the Passenger Compartment Front Strengthener, part: 9823289980, £66.92
Billsy
x 9
Hi Marc can I have the price for a front NS lower control arm, all four seatbelts and an airbag/SRS module please?
x 6946
(5) Wishbone Left, part: 9831626480, £115.90
(1) Pyrotechnic Safety Belt Right, part: 98266702XX, £434.52
(1) Pyrotechnic Safety Belt Left, part: 98266703XX, £434.52
(5) Seat Belt Buckle Strap, part: 98135293XT, £113.96
(1) Seatbelt Right, part: 98412247XX, £341.56
(1) Seatbelt Left, part: 98412248XX, £341.56
(3) Rear Buckle Left, part: 98265554XT, £91.93
(4) Rear Buckle Right, part: 98265562XT, £133.70
(5) Rear Seatbelt Centre, part: 98265640XX, £350.77
(1) Airbag Control Unit, part: 1657637780, £427.40
Billsy
x 9
Thanks very much
StrictlyConfidential
x 5
Unread post by StrictlyConfidential »
What is the part number for Air Con Compressor for DS5 Hybrid VF7**************[VIN obfuscated, can be read by forum staff]?
I found one on eBay https://shorturl.at/cIKS5 but unsure if it will fit my DS5. This part is for 165hp engine, whereas mine is 200bhp.
Billsy
x 9
Hi Marc can I have the part number and price for both bonnet hinges and these please?
Part E and the two screws
The two headlight screws
x 6946
Bonnet Hinges
(2) Bonnet Hinge Left, part: 9823211680, £74.92
(2) Bonnet Hinge Right, part: 9823211580, £74.92
Bumper
(17) Bumper Support Set, par: 1649826580, £46.48
(73) Screw with Washer, part: 623006, £2.45 ea
(Note (73) above is the same screw for the Headlamps)
Jay-Bruce
x 280
Unread post by Jay-Bruce »
Hi Marc, is the pulley for My C5's alternator available separately?
Billsy
x 9
Thanks Marc
Both of my headlights were held in with these
And my wing supports were held on with these
Can you double check the screws please? Maybe mine has the wrong screws in either the wing supports or headlights.
x 6946
Jay-Bruce wrote: 22 Nov 2023, 09:08 Hi Marc, is the pulley for My C5's alternator available separately?
For your 3.0 HDI, Jay:
(3) Alternator Pulley, part: 1611422780, £75.06
(4) Alternator Tensioner Roller, part: 1611424480, £145.94
x 6946
Billsy wrote: 22 Nov 2023, 09:17Both of my headlights were held in with these
Yes the headlight screws are correct: part 623006 (Diam 6-30) Screw with washer £2.45 ea, detail:
Billsy wrote: 22 Nov 2023, 09:17And my wing supports were held on with these:
I'm not sure which diagram you are referring to for the above, as they aren't shown on the wing Schematic: unless you are referring to a different diagram?
Huskyxantia
x 921
Unread post by Huskyxantia »
VF3**************[VIN obfuscated, can be read by forum staff] Needing all part numbers for the front shock,spring and everything else that goes with it need to check what I've got is correct as ive a feeling something is missing thanks marc
:-D
