x 8378
Re: Citrojim's AX, Pixo, C3, Running and Cycling Tales
c16rkc wrote: 15 Nov 2023, 08:26 Next your car will be full of Horse Manure and dead rats... :lol:
:lol: :lol: The garden could do with some! Horse manure that is... Loads going free in the outlying villages... It's a popular sport around here...
If I wanted rats, Milton Keynes is not short of them...
I got told off by a horse rider yesterday... Going too fast allegedly. I passed her going the opposite way at less than 30 in a 40 limit...
NewcastleFalcon wrote: 15 Nov 2023, 09:48 I like to play
Looks like one of those heat-loss diagrams Neil :D
x 5673
CitroJim wrote: 15 Nov 2023, 13:12
We used to collect it from the street after the ice-cream man passed in his horse-drawn chariot.
x 8378
It'as been a bit of a car day today :D Makes a change and as it was such a lovely sunny day I really couldn't resist...
I reset Bluebell's clock to GMT and then prepared her for a warming run. When she's been standing a long time all the fuel in her fuel line runs back to the tank and thus she takes a lot of cranking to get fuel back up into her system.
To avoid battery and starter motor stress, I hit on the idea of using my vacuum tester to prime the fuel system...
Firstly, up to the pump (mechanical on the AX)...
That worked beautifully :)
Then I primed from the pump to the carb. and finally pumped what fuel I'd sucked up into the float chamber...
The pumping force for this was by mouth :)
Result... Instant start and running like a clock from the get-go :D
Whilst she warmed up, I swapped the other dip beam headlight bulb in Polly so that she has a matched set of bulbs as is recommended... Another very easy job :)
Even easier on the offside than on the nearside...
The good one I removed is now an emergency spare and in the car...
I then checked over all three of my vehicles for all the usual things and found no issues at all..
Looking at Bluebell idling on the drive I was concerned to see steam curing up around her front end... A quick look showed this to be apparently issuing fro the front of her radiator. Then her fan cut in and the steam stopped with no reappearance when the fan stopped... At least I know her cooing fan still works!
A good and most lovely test drive showed no problems and no steam was seen at the end...
I guess it must have been a bit of accumulated condensation boiling away...
Something to keep an eye on though.
She really is a joy to drive :)
moizeau
x 429
Unread post by moizeau »
Regarding the fuel leaking back Jim, one of these https://www.amazon.fr/Anti-retour-Alumi ... VWOHR&th=1 placed just before the mech pump ( I'm presuming that's where the air ingress is) would sort it or a bulb, well known on the PSA diesels
Pete
x 8378
moizeau wrote: 17 Nov 2023, 16:13 Regarding the fuel leaking back Jim, one of these https://www.amazon.fr/Anti-retour-Alumi ... VWOHR&th=1 placed just before the mech pump ( I'm presuming that's where the air ingress is) would sort it or a bulb, well known on the PSA diesels
I think one of those non-return valves may well be the answer Pete, thanks for that :D Given how much they cost, well worth a go and happily, I've found them on the UK Amazon site...
An order will be placed very soon...
x 8097
I think I have a non return valve in the garage Jim, it came with my boomerang!! :-D
x 8378
mickthemaverick wrote: 17 Nov 2023, 17:33 I think I have a non return valve in the garage Jim, it came with my boomerang!! :-D
:roll: :lol:
x 2000
Unread post by Stickyfinger »
CitroJim wrote: 17 Nov 2023, 17:38
:roll: :lol:
Remember you will need to install that Up-Side Down..........
x 2341
Unread post by MattBLancs »
Does it save fuel and encourage exercise if installed upside down? (the fuel non return) :rofl2:
x 8097
If you don't want to risk the full blown Aussie version you can always go for the cheap Chinese version, but you have to install that one sideways!! :-D
x 3566
If you put two back to back, does that mean your car will run non-stop ? :-D
x 8378
:lol:
x 8378
Looks like I got out and about a bit last month :D
Google Timeline
Google Timeline
x 5673
Certainly more than me. Furthest I have been is six miles away.
c16rkc
x 104
Unread post by c16rkc »
Wow yes you have!
I do love the fact that you can see where you have been on google maps. I suppose it could be considered a bit creepy too I guess, but it is handy to be able to look at your history :-D
