Difficult cold start on C5 X7 2.0HDi
x 1939
Re: Difficult cold start on C5 X7 2.0HDi
Could there be an air leak in the fuel line allowing fuel to drain back to the tank a bit?
A quick test for this would be first thing in the morning to give the squeezy hand pump in the engine bay a good dose of, err, squeezing before trying to start the engine for the first time that day.
x 1240
Unread post by Peter.N. »
Those engines are usually bombproof, problems are unusual although I have had to scrap the one I had with air in the fuel problem, I think its the high pressure fuel pump and it needs a clutch as well.
If its getting fuel OK I can only suggest that you check the compression figures as it should run. If you spray easystart/carb cleaner or any other volatile liquid direct into the inlet manifold (just take the hose off) it should fire and possibly run for a few seconds, if not I have no idea I'm afraid
Lacrosse
Unread post by Lacrosse »
Paul-R wrote: 12 Nov 2023, 07:48 Could there be an air leak in the fuel line allowing fuel to drain back to the tank a bit?
Did that first time the problem occured (I thought the same as you)...no air in fuel...pump is stiff after first squeez
