c16rkc
x 104
Unread post by c16rkc »
Hi sadly my Citroen C5 X7 has just failed it's MOT because of damaged rear brake cables...
Could I have part numbers for both rear brake cables please?
x 6945
As Matt eluded to Chris (now posted here: viewtopic.php?t=76480), they are only available from Citroen as part of the complete electronic handbrake assembly.
(2) Handbrake Mechanism
Original Part: 470208
Superseded (removal of emergency release cable), part: 1612865480, £1358.58
(73) Closer, part: 698343, £0.92
c16rkc
x 104
Thanks Marc - what are the closers for?
Nhokas
Unread post by Nhokas »
Can you please inform me what is the part number
Thank you
DS7 Crossback plug in 4x4 Opera
x 6945
c16rkc wrote: 26 Oct 2023, 16:39 Thanks Marc - what are the closers for?
These are the bits that go in the ends of the EPB and aren't shown separately on the diagram.
x 6945
Nhokas wrote: 26 Oct 2023, 20:30 Can you please inform me what is the part number
Thank you
(1) Wireless Charger, part: 9813403280, £143.20
(2) Battery Charge Indicator, part: 9816001880, £55.81
(3) Wireless Charger Indicator Light Guide, part: 9816019480, £20.56
(4) Storage Compartment Trim, part: 98215271ZD, £34.19
x 2355
Unread post by MattBLancs »
Hi, not so much a part number request, but check on quantities:
Gearbox oil capacity, 406 Coupe HDi (ML5 manual gearbox)
Haynes reckons "1.9 litres (1.8 after drain and refill)" presumably for all gearboxes. I know that is correct volume for the BE gearboxes, can you confirm same for bigger ML gearbox too please?
VIN VF3**************[VIN obfuscated, can be read by forum staff]
Thanks a lot :)
Edit as Autocorrect/sausage fingers seems keen to generate "496" not "406"!!
x 6945
It's official capacity is listed as 1.85 for the ML5T Matt.
x 2355
GiveMeABreak wrote: 30 Oct 2023, 10:34 It's official capacity is listed as 1.85 for the ML5T Matt.
Spot on, thank you
(Only about 1.5 at most came out, so likely was a touch short!)
GavinPJ
Unread post by GavinPJ »
Morning folks,
I broke the bonnet opening handle under the bonnet of my X7 yesterday after I was topping up the washer fluid and lubing
the lock mechanism. Can I get a part number for it please. Chassis number is VF7**************[VIN obfuscated, can be read by forum staff]. (RHD) Thanks.
x 6945
(9) Bonnet Safety Hook Lever, part: 7937R0, £33.55
GavinPJ
Thanks Marc.
Gbro8936
Unread post by Gbro8936 »
Hi Marc could you please advise me on the correct transmission oil for my ds5 automatic 13 plate as I want to change it kind regards geoff
x 6945
You require JWS3324 oil for your automatic Transmission on your Euro 5 DS 5
x 1074
Unread post by Rp0thejester »
On a serious note, can you supply me with a diagram on what valves to open when doing a coolant change please.
