- x 1083
Re: Citrojim's AX, Pixo, C3, Running and Cycling Tales
I'm sure if your really intent on matching it then a mould could be made using the existing ceiling. Probably would give that ago.
Champion of Where's CitroJim
- x 8437
Yep, that's the basic technique I plan to try Ryan... To be honest, it doesn't need to be perfect as ones' eyes are not drawn to that area of the hallway...Rp0thejester wrote: 27 Oct 2023, 19:55 From what I remember, when they put the ceiling coating on (Artex), they use a screwed up plastic bag to 'drag it down' to create the stippled effect.
I'm making good use of Frog Tape to mask off those items that do not need painting...
I hate, beyond all reason, paint where it really should not be and paint on electrical fittings annoy me intensely...
I can see me using a lot of Frog Tape during my decorating exploits... And Polyfilla
- x 8161
I thought you had had enough of PolyfillaCitroJim wrote: 28 Oct 2023, 06:14
I can see me using a lot of Frog Tape during my decorating exploits... And Polyfilla![]()
- x 8437
mickthemaverick wrote: 28 Oct 2023, 06:27I thought you had had enough of PolyfillaCitroJim wrote: 28 Oct 2023, 06:14
Onlinemyglaren
- x 5679
Unfasten the sockets and switches and let then stand off the wall surface on their wires Jim, less hassle than using masking tape and then removing it.
Which reminds me, I was doing some decorating for some friends and had removed them completely, they were dirty so gave them to the lady of the house to clean.
A big bang when I put one back. She had immersed them in soapy water. Not recommended.
- x 8437
Done that Steve and also masked to doubly ensure a neat jobmyglaren wrote: 28 Oct 2023, 10:12 Unfasten the sockets and switches and let then stand off the wall surface on their wires Jim, less hassle than using masking tape and then removing it.
And I want to be careful as all of my sockets and switches are brand-new from the rewire... My electrician would shoot me if I got paint on them!
- x 1481
For most purposes I find that the yellow Frog Tape is easier to use than the green.
- x 8437
I never knew it came in other colours Mike, I thought it was called Frog Tape because it's froggy greenxantia_v6 wrote: 28 Oct 2023, 15:41 For most purposes I find that the yellow Frog Tape is easier to use than the green.
- x 8161
The yellow one is for delicate surfaces while the green is multi purpose. I think the yellow one is a tad dearer IIRC!!
- x 1083
Don't forget orange which is for satin finishes, I only know that as I have a P and D sitting in my kitchen
- x 1481
The yellow is less sticky and is easier to reposition to get the edge exactly where you want it, and easier to remove when the time comes.
- x 1083
Yellow can also be used on wallpaper as it's a low tack
- x 8437
Thanks all
I now know my Frog Tapes!
- x 8437
Ahh, the joys of owning a modern car!
That came on sooner than expected
Time to be raped by the garage I got Polly from to maintain my warranty
Came on during my trip to Mallory Park this moring for the Duathlon event
On the plus-side, it's a beautiful sunny morning and perfect for racing
- x 2006
more worrying is that you are listening to Leo Sayer !
