Hello All,
My Citroen C5 Estate 2008 was working fine but I decided to clean up the injector a little bit.
The car started behaving erratically after the clean up. It moves well when ignited but stops acceleration when the error code "speed control faulty" code appears on the dash.
What can I do to fix this? I will appreciate any assistance I can get here guys.
Car won't move with error code
- x 6961
Re: Car won't move with error code
It needs a diagnostic with Diagbox / Lexia, then put the fault codes up here with the VIN (or at least state if the car is petrol / diesel and the engine size - 1.6 or 2.0, 2.2, 2.7, 3.0).
- x 1438
It may also be useful to know what you did to clean up the injectors.
