Hello all, I have just purchased a 2020 Expert 1.5. I have a problem with the central locking system. The fob lock button locks all 5 doors, the unlock buttons only unlock the near side sliding door, the 2 front doors and the back door will only unlock using the key in each one, the off side sliding door does not open at all even from inside. On using locking button there is a definitive click as you would expect, but the unlock buttons only give a very muted click just the once. Any help much appreciated. The seller did tell me the n/s sliding door had a fault on locking ( gave me some discount) but nothing about the other doors and i didn't know until I first came to use it after it was delivered.
Thanks for looking and I hope there is someone who can help on this
pk1st
Peugeot Expert central door locking
pk2nd
Reason: Deleted Other Duplicate Topic, Posted Stu's Reply Here (Please don't create multiple posts for the same issue)
Sloppysod
- x 386
Re: Peugeot Expert central door locking
Selective unlocking?
https://www.manuals.co.uk/peugeot/exper ... anual?p=35
Stu
pk2nd
Thanks for the info, gone through it and no luck..When locked key fob remote only opens n/s sliding door. Key will open driver door only you have to then use key to open back and then again passenger front door. o/s sliding wont open at all from outside or inside. the fob will then lock all doors that are open.If related the seat belt sign on dash takes a long time to go out after driving off.
Soot doctor
Hi
Did you get your central locking problem solved.
I have exactly the same problem in my 2020 Expert
Oakleyoakley
- New User
Hi,
Did either of you sort this issue? I'm currently dealing with it now and am running out of ideas
Thanks! Scott
