x 6954
What are you referring to? Your terminology is not standard, so have no idea what you mean. None of those part numbers are recognised PSA parts for this vehicle.
Are you referring to the turbo solenoid valve? If so:
(23) Turbo Solenoid Valve, part: 1618X2, £90.31
vallium
x 15
Unread post by vallium »
Yes, Turbo solenoid t the rear of the engine, thank you
x 2310
Unread post by MattBLancs »
Hi,
Please could I have part numbers and NFP status or cost for 406 Coupe front spring cups (the bit between the spring and the strut bearing) mine are completely rotten seemingly!
Vin
Have a sinking feeling they are likely NFP! :(
x 6954
That boat's sunk Matt: :cry:
(4) Shock Absorber Ball Thrust Bearing, part: 503554, (NFP)
(5) Shock Absorber Bracket, part: 503866 (NFP)
(6) Front Suspension Rest Cup, part: 503142 (NFP)
(7) Shock Absorber Fix Cover, part: 503533 (NFP)
(8) MUL Bolt with Captive Washer, part: 503613
(9) Front Suspension Rest Cup, part: 503147 (NFP)
x 2310
Thanks Marc, swift response much appreciated even if I don't really like the answer! :-D
Part numbers give me something to dig with.
Just for future reference for anyone else in future:
(4) is the bearing and commonly available aftermarket.
Upper rubber mount, seems to be commonly available aftermarket.
Rubber component sits on top of spring, cushioning.
Trim, not present on either of my Coupe's
3 bolts that hold strut on. (Note these are longer, different part number if the (V6 engines) strut brace has been retrofitted.
The bit I need, takes weight of spring and directs through bearing (to body, via alto the rubber mount) made of mild steel.
Thanks again
x 2310
Hi again,
Could I get confirmation the same part for a 607,
"Peugeot 607 Strut Shock Absorber Left Near Side Front 2.0 Diesel 2007"
Vin quoted as VF3**************[VIN obfuscated, can be read by forum staff]
Is also 503147 ? (Parts Asia site seems to suggest so)
In a two-for one, please could you also confirm thw Coupe auxiliary drive belt length?
Currently 6pk1740, but 1750 Also coming up in part searching (vin as before VF3**************[VIN obfuscated, can be read by forum staff] )
x 6954
(4) Part: 503554 (NFP)
(5) Part: 5037C0, NFP)
(6) Part: 503147 (NFP)
(9) Noise Deadening Mounting Part: 503364 (NFP)
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Hi Marc
Could i have the part number for the electronic brake switch for my C4 in my sig and possibly some removal/replacement info.
Colin
x 6954
(2) Electric HandBrake Switch, part: 470703, £94.42
508Allure
x 5
Unread post by 508Allure »
Hi Marc,
Could I get the part number for the front anti roll bar drop links please.
Vin: VF3**************[VIN obfuscated, can be read by forum staff]
x 6954
There's an issue with selecting the OEM part at present for the original drop link - cannot select it, so I can only provide the original part number (OK) but the replacement part number is not allowing me to select it.
(2) OEM Anti Roll Bar Rod, original part number was: 9812361680
Replacement Part Number is: 9844264780
Cheaper version part number: 1679755380
In all cases the nut (5) needs replacing:
OEM, nut for original drop bar: 9807710580
9817224280 (for the later drop link)
508Allure
x 5
Thank you very much for the detailed reply.
508Allure
x 5
Sorry Marc, I forgot to ask for the oil filter parrt number.
x 6954
(2) Oil Filter
OEM Original, part: 1610693780, £18.55
Cheaper Alternative, part: 1680233580, £12.54
508Allure
x 5
Thank you very much.
