mrhardware
- x 4
Hi Marc
Hopefully you can help. Im looking for a part number for the 3 panel clips that hold down the plastic top on the tailgate of a c5 exclusive tourer.
I got some off ebay but the seem to be to big to fit the holes in the tailgate.
Thanks in advance
Thanks in advance
- x 6947
No problem, just let me know which items you need part numbers for from the diagram below:
Rhothgar
- (Donor 2026)
- x 222
Evening Marc,
After a little digging, I have found this:-
https://service.citroen.com/?ref=029106 ... efaff=0291
Can you check and post what this link presents to you please?
Also, on a post from 7 years ago, you posted this picture for a user?
Is there a specification anywhere for the glowplugs for the reheater (part number 6) please?
This is for X435 as per usual...
- x 6947
I don't know what you want me to say about the link - it's the official site that we use for official parts.
(6) Water Reheater, part: 6462T7, £335.04
Glow Plugs / Control Unit
(1) OEM Pre-Heat Glow Plug (M10X100 LONG 107), part: 5960F5, £33.34 each
Cheaper version, part: 1684976280, £10.16 each
Glow Plug Relay, part: 598138, £118.70
Dunkah
- x 11
Hi Marc, can I have a diagram of the engine and gearbox mounts for a 2008 c5 x7 tourer 2.0 hdi
Vin VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks
Many thanks
- x 6947
Let me know items you need part numbers for.
Rhothgar
- (Donor 2026)
- x 222
Thanks Marc. Am aware that it is the official link as it took me to my original login complete with username and password but…GiveMeABreak wrote: 10 Oct 2023, 21:27 I don't know what you want me to say about the link - it's the official site that we use for official parts.![]()
I assumed rightly or wrongly that there some information appended to it as it has a load of reference numbers after it.
Did you click on it?
Maybe it is just a link to the microfiche? I don't know.
So the glow plugs you have shown are for the engine. Is there anywhere that indicates that they are the same for the pre-heater? Are they even removable from the pre-heater?
Dunkah
- x 11
Thanks Marc, numbers I think must be for 1, 10, 13 and 18 or 17 which is ‘a+18’
Thanks again
- x 6947
I've included both (17) and (18) separately in case you don't need 'A'
(1) Anti Torque Link (right), part: 180674, £98.68
(10) Engine Flexible Mounting, part: 184493, £120.70
(13) Engine Flexible Mounting, part: 181398, £222.00
(17) Engine Mounting Bracket (right), part: 1807HT, £147.66
(18) Engine Flexible Mounting (right), part: 180921, £59.54
- x 6947
I don't know what you mean. Glow plugs are powered and controlled by the glow plug pre-heater relay, which is commanded by the engine ECU. The Glow plugs are in the engine - the relay is located elsewhere in the engine bay.Rhothgar wrote: 11 Oct 2023, 07:40So the glow plugs you have shown are for the engine. Is there anywhere that indicates that they are the same for the pre-heater? Are they even removable from the pre-heater?GiveMeABreak wrote: 10 Oct 2023, 21:27 I don't know what you want me to say about the link - it's the official site that we use for official parts.![]()
Re the link - that's just part of the address returned depending on where you are on the site and will change as you clink on elements throughout the site. It will change as you navigate.
OnlineRp0thejester
- x 1083
Hi Marc, super easy one for you, can I get part numbers for rear discs and pads please also an exploded diagram of the O/S/R caliper please.
Champion of Where's CitroJim
- x 6947
(1) Rear Disk Kit
OEM Original, part: 4249C0, £128.62
Cheaper Citroen part: 1618861780, £64.58
(2) Rear Disc Pad Kit
OEM Kit, part: 4254C5, £107.74
Cheaper Citroen Alternative, part: 1617250480, £22.19
mrhardware
- x 4
Thanks Marc.GiveMeABreak wrote: 10 Oct 2023, 11:14 No problem, just let me know which items you need part numbers for from the diagram below:
They look like part 80.
At the top of part 1 which is the door there are 3 holes where they fit and hold part 15 down
- x 6947
Ok, so (80) Clip, part: 1622750380, £0.60p each.
Kenmac15
- x 4
2007 C5 Estate rear wiper linkage.
Afternoon, does anyone know the part number for the wiper linkage that goes through the tailgate glass to the motor as mine is solid & won't move & I know it's this part as the motor tries to turn it but the pin jumps out of the motor. Tried WD40 & Plusgas, 3in1 nothing frees it, so need a new one but without the part number.
Ken
Ken
Reason: Moved to the Parts Thread
Ken
“I have not failed. I've just found 10,000 ways that won't work.”
