Citroen C5 X7 No Satellites Issue
This unit is the MyWay system, also referred to as RNEG, made by Harman Becker.
Main Features: Also referred to as RNEG, the MyWay colour satellite navigation system, has SD card, integrated European mapping, live trafic information, voice guidance and graphics in 2D or aerial perspective & it features a Bluetooth® system (Bluetooth phone compatibility only - no Bluetooth Audio Streaming).
LouisC5
Unread post by LouisC5 »
Afternoon all,
I have recently purchased a lovely low mileage example of the X7 C5 estate (2010 1.6Hdi) with a satnav. However, I am struggling to get the sat nav to pick up any satellites.
What I have done:
- Factory Reset unit
- Update firmware to RNEG R50b R50.03
- Download latest maps (have tried two different versions)
- Bypassed factory GPS receiver with a cheap one off Amazon and stuck it to the outside roof. (Have driven for approx 1 hour with it plugged in)
I’m starting to think the gps receiver in the unit is faulty. Is there anything else to check before I hunt for a second hand one on eBay?
One thing to note is that I have replaced the screen. The original screen was smashed by the previous owner. I replaced it with a second hand unit with matching part numbers. Would this cause an issue?
Any help is much appreciated, thanks!
x 6947
Re: Citroen C5 X7 No Satellites Issue
As long as the screen was the same part number it should be fine.
The satellite issue is generally down to aerial system or the head unit; so given that you have tried a GPS aerial and gone for a drive with this plugged in (it takes a minimum 10 minutes driving for satellites to lock on), it seems like the head unit GPS tuner has failed internally.
LouisC5
It looks to be that way, I have just purchased a screen and unit replacement for cheap off eBay.
I will report back if it fixes the issue.
Thanks!
x 6947
Remember it will need VIN coding too.
LouisC5
Is there someone on the forum I can find/pay to do this for me? Very new to Citroen ownership so didn’t know this was required… Thanks in advance!
x 6947
Have a look at our list of members who have offered Lexia / Peugeot Planet 2000 / Diagbox Diagnostics help if you haven't already seen it - link below:
At the end of the list is a link to a Google Map, showing the geographic locations of members and details. Just use the Private Message or Email links on the member's profile to contact anyone suitable.
List of Lexia / Diagbox Owners with Kits Offering Help
Bear in mind, although we update the list as often as we can, not all members are active on the Forum all the time, so it may take a while for a reply.
