Guide to Replacing the NG4 Navidrive 3D Hard Drive with a CF Card
bolgarwow
Re: Guide to Replacing the NG4 Navidrive 3D Hard Drive with a CF Card
I have image. Total size 25 GB and have some solution:
1. Open torrent file for you
2. you share me place on your PC and I upload
3. your decision
3. your decision
- x 6961
Or just replace it with a CF card and interface insteadof the Hard Disk and reload the latest firmware on it.Lepetitnicolas01 wrote: 12 Nov 2022, 10:52 Salut tout le monde.
Très bonnes explications.
Le disque dur de mon NG4 (TOSHIBA MK4050GAC 40GB) est mort.
Je cherche une image du disque dur pour pouvoir restaurer mon système ?
Je vous remercie de votre aide.
Salutations.
Lepetitnicolas01
Ok, I'm going to try; what is the latest firmware and where can i download it?
Thank you very well for your answer.
- x 6961
@Lepetitnicolas01
Private Message sent.
bolgarwow
Unfortunately, After replacement I had one restart. I will replace EEPROM. On other forum read about it and NG4 also could have this problem.
EEPROM locate under HDD box and should be take apart that make dump and replace.
Which EEPROM chip I used will comment later.
- x 6961
Ok, thanks for the update, let us know how you get on.
sportline
Hello... Our Peugeut 3008 with the NG4 unit has suffered total hard drive damage. I could not make an image of it. Do you have a link where I could download an image file or the data archive? Greetings Philipp
vali_pata
- Locked user account
Hello, My NG4 unit keeps restarting every few seconds and I want to try to replace the hard drive with a Komputer Bay CF card, but I have issues finding a compatible CF-IDE adapter and I also need a the link with the latest firmware.
Can you please help me with this?
- x 6961
No sorry - by the time this sort of thing happens, it generally too late for most people. Your best option if your unit is rebooting or asking for a system CD is to try the HDD replacement with CF card in the guide. The firmware will create the partitions and install the operating system files for you as part of the process. It's the cheapest way also and if it doesn't work, you have only lost the cost of a CF card and and IDE adaptor.sportline wrote: 08 Jan 2023, 20:53 Hello... Our Peugeut 3008 with the NG4 unit has suffered total hard drive damage. I could not make an image of it. Do you have a link where I could download an image file or the data archive? Greetings Philipp
igrikus
Hi. Do you still have your hdd backup file? I can't copy mine, so maybe you can share yours?
- x 6961
Sorry, no. I never needed it as I had my original Hard Disk intact / preserved perfectly working after deciding to upgrade with CF Card. I then passed the original working Hard Disk on to the new owner, as I had no need of it.
- x 6961
Why don't you just undertake the CF card modification?
Assuming there are no errors internally on the chips, then the firmware will recreate all necessary partitions on the CF Card for you as part of installing the operating system.
igrikus
I'll do that. Thanks for advice!
bolgarwow
bolgarwow wrote: 04 Dec 2022, 13:56 Unfortunately, After replacement I had one restart. I will replace EEPROM. On other forum read about it and NG4 also could have this problem.
If anyone will find chip for replacement 24AA64T-E/ST - you can use it with extended temperature diapason until 120C
I did it.
begerowiec
Hello, is there any chances to someone send me disk image? I replaced mine hdd with CF card but before I did it my disk had problems with work and situation with CF card is the same so maybe the disk image is broken.
