DiagBox with Tokens not working
erseraph
Unread post by erseraph »
Hi everyone! I'm having a very vexing problem with DiagBox 9.150, in short:
I own a Peugeot 208 II
I created an account on the official Peugeot/Citroen website and purchased a token.
For some strange reason I couldn't download DiagBox as there was no link to do so, so I found one online.
I connect to the car using the PC and the OBD cable, the initial configuration works very well, it identifies all the components well and I am able to carry out all the tests I want, so the program communicates perfectly with the vehicle.
I logged in to DiagBox and it recognized my token.
I don't understand how to activate/deactivate various configurations such as opening the windows from the remote control, because every time I click on "Telecoding" it gives me an error message in French, if I'm not mistaken it says "ERREUR DE CHARGEMENT DE CELLULE : erreur de chargement dans la cellule: Session=xpert SP=8 Line=17 Column=37 Id=24 File=C:\AWRootldtrd\tree (Vehiclelgenlscript_ readvinauto.s traitement de cellule Impossible." or a similar error.
I don't know what to do anymore, please someone give me an idea.
Thanks... I'm going crazy I was in the car for about 3 hours in the sun
x 6954
Re: DiagBox with Tokens not working
You can't enable a function that isn't designed for the vehicle!
Many PSA vehicles that had this function back in 2001 (my first C5 did), but on the C5 MK II in 2005 that function was removed and was not possible to code.
According to the later 208 owner handbook, the only function for the middle fob button is the tailgate unlocking and the guide me home lighting. There is no option that I can see for enabling what you want. The later C5 (MK III) could close all the windows when the vehicle was locked, but as for opening the windows when the car is locked, that is no longer an option and why Diagbox is giving you an error - it cannot do what is not possible.
x 1055
Unread post by Rp0thejester »
I had the same error message in french when I first used diagbox. It turns out it wasn't installed properly. I would suggest re installing again. Once installed properly you won't get that error message as either diagbox can do it or not. If not, it won't give you the option so no error message
erseraph
Thank you both for your replies! GiveMeABreak I know that I can't enable functions that are not designed for my vehicle, but I didn't know that this is a function that I can't enable. Anyway thank you because I learned something new with your response. The only problem is that I can't even see the list of possible configurations because the error Im having. Rp0thejester okay I get it I need to try it. Thanks both again!
erseraph
I discovered a thing: I was trying again and I found the list of functions enabled/disabled. I found what I was looking for "Open windows on key fob button holding" (something like that) and his value was NO. I cannot change it, doing that will result on the french error message. I know this is an anomaly because next to it there was "Close windows on key fob button holding" and his values was YES and indeed I can do that. Tried to disable it, same french error message. I don't know what to do, I can view this settings but cannot change even with tokens...
x 6954
You have to understand that the BSI are cross-range and there may be some options that are not applicable to your car as I said. So it may not be allowing you to change the option if that feature is not available.
erseraph
I got it working. For those that receive the same error, just reinstall a couple of times DiagBox, just some patience and it will work. I've enabled windows opening with key fob, disabled yellow light when locking the vehicle and enabled adaptive cruise control, this one is a bit strange because if you have manual trasmission you have to shift gears every time
x 1055
Yeah I had the same problem, that error message means something hasn't installed correctly. I'm glad you've sorted your problem out :)
ezejp
Unread post by ezejp »
Rp0thejester wrote: 30 Sep 2023, 17:20 Yeah I had the same problem, that error message means something hasn't installed correctly. I'm glad you've sorted your problem out :)
Hi, can you tell me how can I buy a token for Peugeot Car? thanks
x 6954
You have to do this via Citroen's independent repair site here
Djandree
x 38
Unread post by Djandree »
erseraph wrote: 28 Sep 2023, 16:22 Hi everyone! I'm having a very vexing problem with DiagBox 9.150, in short:
Hello
How did you log in? Got account, token I am trying to log in with my Servicebox user name (ANXXXX) and so far - error 105 Diagnostic connectivity failed
Regards
Andy
