Dunkah
- x 11
Excellent, thanks Marc, I need Toru? these by a mechanic friend so he can let me know which part but I’ll get back to you soon as
Thanks again
Thanks again
- x 2337
Hi,
Could I check if Peugeot 406 (coupe but generic across the range) rear anti roll bar clamp brackets - I think are 5172.41 - are they NFP? or if not, could you confirm the price please?
No rush, thank you, will dig out the VIN in the morning if required.
Matt
Matt
- x 1056
517241 is showing as NFP.MattBLancs wrote: 22 Sep 2023, 21:16 Hi,
Was £26.42 + V
Moog
Hi Marc.
Would have the Citroen part numbers for the following:
O/S steering rack boot
O/S track rod end
N/S driveshaft seal (into g/box)
2001 Xsara Picasso 1.6 8V
VIN VF7**************[VIN obfuscated, can be read by forum staff]
My local parts shop is pretty useless so I'll have to try the main dealer.
Many thanks for your help.
All the best!
O/S track rod end
All the best!
- x 6956
(4) New OEM Steering Rod Ball Joint, part: 381750, £59.23
(4) Cheaper Alternative Steering Rod Ball Joint, part: 1682870080, £12.14
(14) Steering Rack Boot, part: 406662, £21.88
(15) Steering Rack Boot, part: 406643, £23.06
Any other part numbers required on this diagram or the one below, let me know the item number:
Driveshafts
Driveshafts
joro_371
Hi Marc, i need parts as per PM. Can you help me with that.
- x 6956
(8) Rear Body Height Sensor, part: 5273J9, £92.11joro_371 wrote: 24 Sep 2023, 17:28 Hi Marc, i need parts as per PM. Can you help me with that.
(10) Angular Pick Up Link, part: 527381, £7.89
(11) Anti-Roll Bar Lever, part: 1687269980, £312.05
OnlineRp0thejester
- x 1067
Can I get a part number for a new Dpf for my C8, yes I know it's unavailable from Citroen
Champion of Where's CitroJim
- x 6956
Hi Ryan, these are available from PSA...
(12) New Original Octo Square Particle Filter, part: 1731NG, £924.53
Exchange Particle Filter, part: 174035, £1234.73
(Yes, double checked and the exchange is actually listed as more expensive than a new OEM one).
OnlineRp0thejester
- x 1067
Thanks bud, that's well appreciated!! I know not many here has a C8 so every little bit info helps!!!!
OnlineRp0thejester
- x 1067
would this fit?
- x 6956
Can't advise on Aftermarket Ryan - you have the official part numbers and they state one of them so maybe worth a chance, or contact them to be sure.
Romtag
- x 8
Hi Everyone,
Somehow without me noticing, the door window rubbers around the rear left window of my 308 SW has broken.
Can anyone share the part number so I can try and source a replacement.
Also fitting instructions if possible
Reason: Moved to parts thread
Mark
Owner of a 2013 308 SW
- x 6956
Mark: I've moved your post here - your membership upgrade entitles you to request official part numbers, so in future just pop them up on this thread.
(11) Rear Door Weatherstrip (left), part: 902593, £42.35
(12) Rear Door Weatherstrip (left), part: 902595, £40.06
(10) Door Window Lower Outer Seal (Left), part: 931183, £45.12
(11) Door Window Lower Internal Weatherstrip (left), part: 931184, £39.10
C5X7_2_2HDI
- x 4
Hello Marc
My C5 is in need of a new rear left caliper. I was hoping you could provide me with a part number for caliper AND mount that slides on the caliper.
I am assuming it is different to a normal one as mine is electricly operated
My VIN is VF7**************[VIN obfuscated, can be read by forum staff].
Thanks in advance!
Thanks in advance!
