TANK FAULT
SPARKLES123
TANK FAULT
Unread post by SPARKLES123 »
Service light appeared today.."TANK FAULT"
says to check user manual and arrange a repair.
DS7 E-TENSE 2020
Anyone have any idea what might be facing me please?
x 6955
Re: TANK FAULT
What are you referring to - the Adblue Tank warning? The entire message would be helpful.
SPARKLES123
Re: TANK FAULT
It is pretty much as I said.
TANK FAULT: Refer to vehicle handbook and have vehicle repaired.
x 6955
Re: TANK FAULT
That would indicate an issue with the tank gauge. Your range indicates low range remaining - are you in the habit of running the car with low fuel levels? If that's the case not a good idea as this is where all the gunk accumulates and can get into the fuel system and can play havoc with the gauge. I think the manual also recommends not to do this.
I'd get it to DS for a diagnositc.
