AT6 SOLENOIDS
508c5
x 4
AT6 SOLENOIDS
Unread post by 508c5 »
Hi,
can anyone confirm whether the 2 solenoids in the pics are the ones that are fitted in the pic of The hydraulic block ?
can you say which one is which ? i.e. which one of the two corresponds to which one in the block
https://cars245.com/en/item/vemo-V42770 ... nsmission/
vin VF3**************[VIN obfuscated, can be read by forum staff]
thx
508c5
x 4
Re: AT6 SOLENOIDS
Am I correct in assuming that the solenoids in the links are the one marked in the attached pic ?
there is a good 3D simulation in this link https://maktrans.net/valve-body-tf80-2gen
x 6956
Re: AT6 SOLENOIDS
I can't help you with that, PSA only provide the complete hydraulic block as a replacement part and not the solenoids.
508c5
x 4
Re: AT6 SOLENOIDS
GiveMeABreak wrote: 21 Sep 2023, 09:59 I can't help you with that, PSA only provide the complete hydraulic block as a replacement part and not the solenoids.
thanks
can you confirm the exact model number of the gearbox? is it TF70SC TF72SC TF80SC ... other ?
x 6956
Re: AT6 SOLENOIDS
Those are Aisin Designations, not PSA designations.
Gearbox: AT6 Automatic Gearbox
Final Drive Ratio: CP 15 X 58
Marking: GA03
Official PSA part number for new Gearbox: 9813948380, £11,486.12 ( :shock:)
New Hydraulic Box, part: 2570J4, £2,463.94
Exchange Hydraulic Block, part: 1682611580, £1,495.31
