x 2326
Unread post by MattBLancs »
c16rkc wrote: 05 Sep 2023, 14:36 What a wonderful thread Matt, I have really enjoyed reading it from start to the current day. Not only is your writing style very enjoyable to read; but I envy your mechanical abilities!
Keep up the great work!
Thanks very much! I'm made up that you're enjoying my ramblings :-D
x 2326
Think car washing is on the cards for this weekend then!
C5 sunroof with extra shading
x 2326
x 2326
Don't think the home brewed version was too much of a downgrade really, but new plate £7-something worth it anyway
Spot the difference!
x 8310
New plates always look good Matt :)
x 2326
myglaren wrote: 03 Sep 2023, 19:05 Apologies about the Americanish,
Trying without the heat (or salt for first attempt)
Before
Before
Dipped
Dipped
x 8310
Be good to see the result Matt, old Citroen wiring can be hard to solder when like that... Those could be quite brittle too...
x 2326
Experiment 1: a failure, as I foolishly left it hanging by the duct tape sticking the neck of the bottle to the cable further up and gravity had other ideas.
Now reinstated at ground level. Very slightly more copper coloured I think, but no idea how long it actually remained in the vinegar!
As obviously:
I've been off to the tip! :)
x 3566
Edd China shows a short similar copper wire cleaning process but without the heat involved. He says it should only take minutes. There should be a 'Part 2' to this where you neutralize the process with a solution of Bicarbonate of Soda and water in similar proportions to the vinegar / salt, but you only need to swill the wires around in the bicarb to neutralize it.
x 2326
I'm calling that a success! Just vinegar no salt good few hours. Quick rinse in water and I'll call that right!
Ta da!
Ta da!
Pressure washer out (for that Sahara sand mess clean up) = rain drops before I've even coupled up the hose! :-D
x 8310
That looks excellent Matt :)
x 2326
Finished work early for a bonus mid-week tip run!
Familiar sight!
Familiar sight!
Yesterday's pressure washer marathon meant I missed the silly 5pm tip closure yesterday
x 8310
Excellent! Always good to see a car earning its living :)
I have a lot of dead kitchen to take to the tip today and found a great use for my now redundant blue glass recycling box - it makes a great rubble skip!
Redundant because the council have recently introduced a new wheeliebin regime...
x 2326
157,777 miles covered in the Coupe on the way to work this morning. On my own so no chance of a picture unfortunately. Weather miserable. First go with the "new" Coupe's auto wipers, a couple of instances of "quick, flick to hummingbird mode despite no actual change in rainfall rate" or basically same as every instance of auto wipers I've ever come across! :)
c16rkc
x 104
Unread post by c16rkc »
What were the stripped wires from, I seem to have missed that part?
Just in case you don't know - If you do need to solder, make sure you don't buy the "lead free" solder as it's a pain (due to the higher melting point). The solder you want is often known as "60/40" because it has 60% tin, and 40% lead.
I bought the lead free solder off the shelf in Maplin without thinking about it, and it puzzled me for weeks why I was struggling more than I usually do.
