Hi all,
I new on here so pls let me know if I miss out any vital info...and thanks for any help in advance. I've not got the VIN number to hand currently but can get hold of it.
My girlfriend & I bought a 2017 Citroen Relay to convert into a campervan & the conversion has been the easy part...we've had a load of issues surrounding injectors & oil loss that ultimately led us to having the engine (replaced with a reconditioned one), turbo, radiator and all of the relevant seals & gaskets replaced by our local garage (the full story is long but if anyone thinks it would help come to a solution then let me know & I'll write it all out). The garage test drove the van a few times before I collected it & all was fine. However when I first drove the van, with a couple of miles of the garage, I noticed what I can best describe as a stuttering under acceleration. It's not consistent as far as I can tell & the acceleration doesn't need to be at all aggressive (say around 2000rpm).
We're getting the following codes:
U1218-81 - built-in systems interface: communication not valid
U1113-87 - ABS/ESP ECU: absense of communication
The air mass sensor has been replaced to no avail.
Otherwise, the van is seemingly working fine. Any bright ideas or cunning ways of narrowing it down?
Citroen Relay - stuttering under acceleration after engine replacement
Chaplin_Harry123
- x 1083
Re: Citroen Relay - stuttering under acceleration after engine replacement
Are you changing gears at the point then it starts stuttering?
Champion of Where's CitroJim
Chaplin_Harry123
No, not changing gears.
