Peugeot 5008 2019 strange behaviour
kingpatrikro
Re: Peugeot 5008 2019 strange behaviour
Unread post by kingpatrikro »
A mechanic mentioned that it might be due to AdBlue being disabled, and they believe that the connector on the reservoir might have been removed, possibly allowing water to enter it. However, they cannot be certain as the error showed on the test that it couldn't connect to the urea module.
kingpatrikro
"I am very upset because I paid 20k euros for it, and I switched from a 2001 Mitsubishi Pajero 3.2 diesel, which, aside from some issues with the starter motor and one headlight, had nothing wrong with it. The car ran for 8 years with the same oil, just to show you the difference in quality...
x 6945
That will only be a temporary solution as some faults are reset after one or more engine restarts, but it won't resolve the underlying issue (s).
kingpatrikro
Any News guys?
x 6945
As I suggested previously there are simply too many faults to deal with and are likely to be something underlying like the engine Fuse box, Supplies and protection module / BSI possibly. But this is just guesswork and I suggest it may save you time and money by going to a good dealer rather than garage to garage without any solutions.
A dealer will have full online diagnostic and French Tech. Support to try and resolve your issues. They charge a standard diagnostic rate for up to an hour of diagnostics and will discuss findings before going ahead with any repairs.
Had this been one or two faults, we could help with likely causes, but with so many systems affected it needs proper investigation.
kingpatrikro
Okay, I understand. Thank you for the suggestions. I think I'll go to Bucharest, the capital of Romania, to see what's going on there. Maybe the professionals there can provide better assistance. At Eurial Ploiesti, they told me it could be the high-pressure pump, the diesel pump, faulty injectors, the particulate filter, and so on. With all they've mentioned, it might be better for me to get a new engine:))))
x 6945
Exactly - All guesswork and potentially more expensive than a proper diagnostic.
kingpatrikro
Thanks again, guys, for the answers and help you've provided me
