Fault reader
Killerdelts
Fault reader
Unread post by Killerdelts »
After a fault reader not to expensive just want one that reads fault codes thanks
x 1938
Re: Fault reader
Do you want one that only reads some of the codes (cheap) or all the codes (not so cheap). You can't have a cheap one that reads all the codes.
Dustysweeper
x 20
Re: Fault reader
Unread post by Dustysweeper »
I use this for quickness. It catches most issues. The only thing it won't read on my picasso is the steering angle sensor, it reports isas missing.
iCarsoft CR Pro Full Systems Diagnostic Scanner Code OBD2 Tool 2022 (check your make and model before you purchase) https://amzn.eu/d/6DyV2I8
Killerdelts
Re: Fault reader
I've got problems with parking sensors and oil pressure sensor
Sloppysod
x 392
Re: Fault reader
Unread post by Sloppysod »
Killerdelts wrote: 02 Sep 2023, 20:19 I've got problems with parking sensors and oil pressure sensor
what's the problem with your sensors, simple but effective check is when active, ie vehicle in reverse, you should be abke to feel a a very slight vibration, no vibration duff sensor, but you do need a tender touch like Pointer Sisters 👍😁
Stu 🏴󠁧󠁢󠁷󠁬󠁳󠁿
