Rhothgar
- (Donor 2026)
- x 221
Afternoon Marc,
Please may I have microfiche for engine mounts and part number specifically for top mount for VF7**************[VIN obfuscated, can be read by forum staff], my HDi, when you get a moment?
Thanking you in advance.
- x 6945
Please advise of specific item numbers you need part numbers for.WindyMiller wrote: 22 Aug 2023, 15:30 Hello, can I put a request in for:
VIN VF3**************[VIN obfuscated, can be read by forum staff]
I am after diagrams and part numbers for all of the engine and gearbox mounts please.
- x 6945
Please specify item number for the ones you need a part number for Roger.Rhothgar wrote: 22 Aug 2023, 15:33 Afternoon Marc,
WindyMiller
Hello Marc,GiveMeABreak wrote: 22 Aug 2023, 15:52WindyMiller wrote: 22 Aug 2023, 15:30 Hello, can I put a request in for:
VIN VF3**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
Parts:
1
14
13
5
7
21
Jonathan
Rhothgar
- (Donor 2026)
- x 221
Part 11 please with any associated dimensional info please.
Plus the bushing indicated on this photo. Though it doesn’t seem to show a bush separately. I was a little confused as to why 11 is shown the way it is when you can see the bush in the housing too?
- x 6945
NFP = No Longer Available From Peugeot
(1) Reaction Link Attachment, Right(), part: 185420, (NFP)
(5) Engine Flexible Mounting (Right), part: 182723, £101.14
(7) Engine Flexible Mounting (Left), part: 182710, £90.23
(13) Engine Flexible Mounting, part: 180916, £57.80
(14) Vibrate Weight, part: 184679, (NFP)
(21) Engine Flexible Mounting, part: 180917 (NFP)
- x 6945
(1) Engine Mounting Bracket (Right), part: 183946 (NFP)Rhothgar wrote: 22 Aug 2023, 17:11 Part 11 please with any associated dimensional info please.
(11) Engine Flexible Mounting, part: 180916, £57.80
The bracket (1) would of come complete with the bushing Roger, so correctly, as you surmised, the bush is not sold by Citroen Separately and there's no further detail supplied on size or dimensions.
However, Googling the part (183946) brings up some bushings on some sites, but the complete support and in stock on this Polish Site:
https://www.franceauto.pl/pl/p/PODUSZKA ... 3946/66120
Rhothgar
- (Donor 2026)
- x 221
Thank you kindly, Marc.GiveMeABreak wrote: 22 Aug 2023, 19:05(1) Engine Mounting Bracket (Right), part: 183946 (NFP)Rhothgar wrote: 22 Aug 2023, 17:11 Part 11 please with any associated dimensional info please.
508Allure
- x 5
Hi Marc,
Can you please identify which Peugeot model the below part number fits?
It was listed for a 2016- 3008 but it certainly doesn't fit my car, so I am suspecting it's for a 5008, which I assume have longer rear doors but I can't find any online confirmation:
9814134077
Many thanks.
9814134077
Many thanks.
- x 6945
That's not a valid part number coming up against any Peugeots, sorry. Why don't you ask for the part number you actually need and then you can use this to search for alternatives which may list the international part number?
508Allure
- x 5
Unfortunately not all Ebay sellers show part numbers and this particular part was being sold by a vehicle breaker and listed as being for a 2016- Peugeot 3008, which it clearly isn't when held against the original part on my car.
I swapped the last two digits of the part number I gave you from 77 to VV and it's for a 5008, which makes sense given what I suspected was a longer rear door.
I was just trying to find what it actually belongs to before I go back to the seller.
- x 6945
PSA often have their own internal part numbers and that's why in this case it isn't valid - and despite your images of it being printed on the component, it does not follow that this is what PSA use for their parts system.
Like I said, if you want the correct official part number, tell me what it is you want and then you can search the aftermarket on the official number - problem solved. Doing it the other way round is pointless as often the aftermarket / ebay databases aren't even accurate.
dylan26__
- x 22
afternoooon! can i get the part number for the eolys / Fap / DPF fluid what ever you wanna call it please!
- x 6945
Hi
Your vehicle has a flexible pouch instead of a reservoir and needs Powerflex Additive. Don't forget to reset the additive counter after you have replaced it.
The pouch is 1.7 Litres and the part number is: 9678034080. £207.92 from Citroen inc. VAT
or Neo Bros have their equivalent for £49:
https://www.neobrothers.co.uk/car-parts ... 9678034080
dylan26__
- x 22
GiveMeABreak wrote: 25 Aug 2023, 19:52 Hi
I will reset it, thank you
