2015 Renault master 2.2 dci Map sensor location
This is the Forum for all your Renault Technical Questions, Problems or Advice.
grahamh123
Unread post by grahamh123 »
Have the fault code P1070 but cant find the MAP sensor. Must be on the inlet manifold before the turbo but where?
TIA
grahamh123
Re: 2015 Renault master 2.2 dci Map sensor location
of course I mean 2.3 135 dci, Doh
grahamh123
Well for interest the MAP sensor is at the right hand end of the inlet manifold. Held in place with one 8mm bolt. Removed tested and replaced. Fault code gone. Total cost £22.30 from partsinmotion.
Job done
