Ford KA 2011 1.3 TDCi Gear / Clutch problem
- x 1083
Re: Ford KA 2011 1.3 TDCi Gear / Clutch problem
So did you chop your daughter's leg off for resting it on the clutch pedal?
Champion of Where's CitroJim
Skull
- (Donor 2026)
- x 382
Rp0thejesterRp0thejester wrote: 13 Aug 2023, 17:34 So did you chop your daughter's leg off for resting it on the clutch pedal?
No, I just pointed to the 'made for that job' wedge, next to the clutch pedal .....she was amazed
Gary
Gary
- x 2366
Gosh, that clutch looks pretty tiny! I would have guessed it would have an order if magnitude larger than the tiny clutch in my sister's '97 (original generation) 1.3 Kent engined Ka (worn down to the rivets at something daft like just 31,000 miles covered. When gearbox came off, this tiny little thing made it obvious why such a short life!
Skull
- (Donor 2026)
- x 382
MattBLancs I know what you mean, but I would guess 150K mixed driving is easily achievable given the friction disc condition, the abuse killed it early in this case!
Gary
Gary
