jollyfj
Hi,
Researching the emissions problem on the Aircross. I've come across two different part numbers for the NOx sensor.
9816276480 and 9811207180, seem physically identical. Superceded part or have there been changes in the exhaust and the photos are wrong?
VIN is VR7**************[VIN obfuscated, can be read by forum staff]
Cheers.
Cheers.
- x 6957
Well I cannot find ANY solenoid valves apart from the one in the last diagram. Usually these are shown on the EGR Circuit (first diagram below) for 4 cylinder engines, but on this V6 they are not shown. I've looked at all the other likely related places and cannot find anything apart from the last diagram.407 wrote: 07 Aug 2023, 12:18 Hi Marc
Can you provide the part number for a Turbo Pressure Solenoid Valve for the Peugeot 407 2.7 HDi
Its the one that sits on the rear left hand side of the engine just behind the inlet manifold.
The numbers I found are 4M5Q9E882AA 70051800 SIEMENS
regards
Gas Recycling Circuit Turbo Air Piping Turbo Oil return Air Intake Vacuum Circuit Pipe Set For the above which is the only thing I can find with a solenoid valve in is part: 1622HW, £220.81
- x 6957
Hi (and welcome).jollyfj wrote: 07 Aug 2023, 13:05 Hi,
Cheers.
Before I start, your vehicle is being flagged up with an aftersales campaign. I would call the dealer and quote your VIN - they will be able to tell you what it is for, but I wouldn't leave it - and the work will be free of charge.
Ok, so to answer your question neither! This vehicle has 2 NOx sensors:
(5) NOx sensor Downstream of the particle filter, part: 9811207180, £378.72
(6) NOx Sensor Upstream of the Catalytic Converter, part: 9816276480, £394.79
- x 22
Thanks Marc
I think its No 1 in the Air Intake Vacuum Circuit Pipe Set (the second last one in your response)
Looks like this one
Looks like this one
- x 6957
There you go then - not sold separately from Peugeot, only as part of the kit - part and price as I've listed
So if you have the old valve, check the part number on it and see if you can buy that in the after market.
- x 22
Thanks Marc as always
There are a few of these turbo valve units numbering 1618.XY that externally look the same but appears to only "fit" the 1.6, 2.0 etc turbo.
Assuming the electrics is just a dumb magnetic push / pull solenoid to open the air / vaccum at the right time, do you think this might just be a PSA "marketing ploy"
This one also have these reference numbers OEM Part Number: 1618C9, 9652570180, 1313848, 3M5Q9E882CC, 30711101, 9652997580, 7.00968.04.0, 7.00968.03
I might by the cheapest and report.
ps - Im trying to trace why my twin turbo is now sometimes not generating boost and suspect the vaccum line / valve.
- x 6957
Any tech queries, please create a separate post in the Peugeot Forum, nut the only way to really test the operation is with a vacuum measuring tool. The part number I supplied is for the kit, so there is no separate part for the solenoid. V6 engines have many different components, so have a good look at any markings or numbers on your existing solenoid to see if you can search on those.
Huskyxantia
- x 904
Need part number(s) for inner tie rods for peugeot 207 vin is
Many thanks.
Many thanks.
Husky.
- x 6957
(1) OEM Steering Connection Rod Kit, part: 3812E8, £68.96
Cheaper Peugeot Alternative, part: 1635769980, £23.66
508Allure
- x 5
Hi Marc,
When you get a minute could I please have the part number for the drivers seat massage button, which only seems to work intermittently, although the massage works great when it does?
Many thanks.
Many thanks.
- x 6957
(16) Massage Switch, part: 9812779680, £38.64
508Allure
- x 5
Thank you very much.
Can I also trouble you for the part number of the drivers side rear door lower moulding with the chrome strip (photo attached)? Thanks
- x 6957
No problem
(15) Door Protector
Left, part: 98114045VV, £209.05
Right, part: 98114033VV, £221.10
(15) Door Protector
vaho
Hi. New to the forum and have trouble finding a driveshaft and/or CV joint left side for 2013 DS5 1.6 THP 115KW
Thank you!
Thank you!
- x 6957
Here you go:
(1) New Citroen OEM Driveshaft Left, part: 3272WS, £612.07
Citroen Exchange Left, part: 3272WT, £412.66
(2) New Citroen OEM Driveshaft Right, part: 3273XK, £612.07
Citroen Exchange Right, part: 33273XN, £292.70
(3) Gaiter Kit part: 329331, £41.90
(4) Gaiter Kit part: 3287A9, £46.12
