Can someone tell me where I can find the MAP sensor?
Thanks in advance.
MAP Sensor Xantia 2.0 HDi
Edhertz
- x 4
Alan
1999 Xantia Exclusive 2.0Hdi Mauritius blue
1999 Peugeot LX 1.9D silver
- x 6955
Re: MAP Sensor Xantia 2.0 HDi
Here you go, item (4) where I've highlighted:
Click Image to Zoom
Click Image to Zoom
| Air Circuit Component | Reference |
| Air Cleaner | 24 |
| Air Flow Meter | 5 |
| Turbocharger | 25 |
| Inlet Manifold Pressure Sensor | 4 |
| Air/Air Heat Exchanger | 26 |
| Exhaust Gas Recycling Valve (EGR) | 27 |
| Turbo Waste Gate Control Valve | 28 |
| Recycling Regulation Electrovalve (EGR) | 29 |
| Turbocharging Pressure Regulation Solenoid Valve | 30 |
| Exhaust System | 33 |
| Vacuum Pump | 48 |
Edhertz
- x 4
Thanks, Alan
Alan
Rhothgar
- (Donor 2026)
- x 226
This diagram makes no sense to me. Is it the NipponDenso sensor in the intercooler. The diagram looks back to front.GiveMeABreak wrote: 22 Jun 2023, 23:59 Here you go, item (4) where I've highlighted:
Click Image to Zoom
Air Circuit Component Reference Air Cleaner 24 Air Flow Meter 5 Turbocharger 25 Inlet Manifold Pressure Sensor 4 Air/Air Heat Exchanger 26 Exhaust Gas Recycling Valve (EGR) 27 Turbo Waste Gate Control Valve 28 Recycling Regulation Electrovalve (EGR) 29 Turbocharging Pressure Regulation Solenoid Valve 30 Exhaust System 33 Vacuum Pump 48
- x 6955
If this is for your own 2.0 HDi, then it's probably because the parts diagram provides less detail (13), so that's why I put up the system diagram that shows its location as a sequence
Edhertz
- x 4
Thanks , Alan
Alan
