Xantia Heater/Blower problem please help.
nitro74
Unread post by nitro74 »
Hello
In my Xantia(95N td sx) the heater/blower started to act strange, it will work absolutely fine when the ignition is on BUT when I start the engine it stops. to make things worse they act together with rear window demister switch. Both wont work when the engine is running. Did anybody experienced the same problem? any advice will be very helpful and appreciated. If I can't sort this out driving in winter will be a pain. also if this problem mentioned before, sorry I just find this website.
many thanx
Richard Gallagher
Unread post by Richard Gallagher »
A familiar problem with the ignition switch which needs replacing.
Search the forum and you will find numerous threads telling this tale.
johnlyn
Unread post by johnlyn »
Nitro, I have got an ignition switch here if you are interested no keys though, but you should be able to dismantle both & make up a good one.
John
Clogzz
x 40
Unread post by Clogzz »
Clogzz
x 40
nitro74
Thank you very much
