x 1498
Appears it is not fitted - assuming we are talking about the 308CC?- it would be 3 or 4, but no part listed against the VIN.
Huskyxantia
x 928
Unread post by Huskyxantia »
Hi Marc can i have the part number for a 308cc 1.6hdi heater matrix my vin VF3**************[VIN obfuscated, can be read by forum staff] i understand there are o rings that not all come with the matrix They are 16mm Id with 3.5mm cross section is this correct ? Cheers.
:-D
x 6950
(1) Heater Kit, which includes all the parts highlighted in circles in the diagram.
Part: 6448V6, £356.86
If there are any other items on this diagram you need, let me know.
Huskyxantia
x 928
I might need Part k Marc.
:-D
x 6950
That's included as 'K' in the kit (1), along with items A, B, C, D & E. K is not available separately.
x 22
Unread post by 407 »
Hi Marc
can you confirm the part number for a brake light switch for the 2007 407 2.7 hdi
I suspect its one of (or all of) 4534.67, 9650688480, 9665602380,4534.63
My cruise control has stopped working - was fine last week
ps - I did search the parts forum for brake light switch but it said zero :)
cheers
x 6950
Ok so be aware there's a technical bulletin concerning this if you are getting malfunctioning of the stop lamps / and or lighting of the ABS / ESP warning lamp on braking.
It requires the installation of an intermediate electrical harness and replacement of the brake lamp switch.
(15) Strap Stop Switch Kit, part: 453467, £58.19
The kit contains the harness as shown below:
Let me know if you require the repair instructions for this and I'll put it up in the Member's resources section for you.
x 22
Thanks Marc
if you could post the repair instructions up thanks
I have no warning lights / ABS is okay but the cruise control just stopped working. Brake lights work okay.
I recall replacing this on my petrol version a few years and so might have the cable somewhere as I did not use it :)
x 6950
darbuck
x 289
Unread post by darbuck »
Hi Marc can you post up the part number for the crank case ventilation hose please for my C5 please it's a 138bhp 2.0 HDI.
Darren
x 6950
(3) Crank Case Gas Breather, part: 1180N3, £19.04
(4) Oil Vapour Hose, part: 1192Z7, £46.96
darbuck
x 289
Thanks Marc, would you be able to see if there is a method of removal for it for future reference please.
Darren
dylan26__
x 22
Unread post by dylan26__ »
Evening! Could i get the blower motor resistor please.
x 6950
(5) Heater Motor Control Module, part: 6441S7, £195.38
C5X7_2_2HDI
(Donor 2022)
x 4
Unread post by C5X7_2_2HDI »
Hello Marc,
My C5 X7 is in need of replacement of FRONT and REAR wheel bearings VIN is VF7**************[VIN obfuscated, can be read by forum staff].
If you could be so kind and post a replacement procedure for both FRONT and REAR bearings on the resources section please?
Much apprechiated!
Cheers!
