Diagbox 9.129 felkod B1003-00 on 508 SW1 bluehdi 1,6l
Marian
Re: Diagbox 9.129 felkod B1003-00 on 508 SW1 bluehdi 1,6l
Unread post by Marian »
Exactly,
I replaced it with a part with the number 9662872380-00. made 2012/05/30.
Now that you are asking I notice that the last two numbers differ. My original is 9662872380-05.
Can this make a difference for the the specs?
/Marian
x 6954
Ignore the last 2 numbers, your part has been replaced - and make sure you get a genuine PSA one like this:
https://www.neobrothers.co.uk/car-parts ... 9827870080
Marian
Thanks, I will try.
But meanwhile: here we go,
configuring settings i BSI:
1. clutch compressor is - !absent!
seems very wrong to me.
Other settings:
2. Variable capacity compressor - "present" (is that supposed to mean the opposite of a clutch type compressor or is it even right as present?)
3. Coolant heater - "absent"
4. Pump type - "air conditioning coolant pump"
Is that something that I can try to change?
I will try to shoot a better pict.
/Marian
x 6954
Bo, that's no odd, becssue there are some compressors without a clutch...like this:
Marian
Hell, I dunna how, but it worked out!!
Although Diagbox reported that it couldnt be telecoded and led to a configuration fault - again. But miracolously the clutch is engaging now and a chilly breeze is entering the car! Thanks for helping out and safeguiding! Really appreciated!!
x 6954
albdiag
Unread post by albdiag »
Hi
I have exactly the same problem on a citroen c4 2014.
What changes did you make to the coding so your AC worked?
In your last post you said the configuration you did see in the Bsi but you dis not say what u changed that it make it work.
Please explain
Thx
