2010 C5 rotation noise in front end
Trotty
I have a 2010 citron c5 with a rotational noise in the front end have replaced wheel bearings both sides and the centre bearing on the drive shift to no result advise would be very thankful.
- x 6953
Re: 2010 C5 rotation noise in front end
It may well be the hub in that case.
Trotty
Hi mate the hub has been checked and is in good condition but there's still and winding noise that vibrates through the car from 60kms onward and gets louder as u go faster but when I apply the brake it disputes very quickly
Dustysweeper
- x 20
Tyre noise. I had two new tyres fitted. Couldn't work out where the whining was coming from until I rotated the tyres back to front. Noise shifted to the back. Cost me a driveshaft and a wheel bearing.
Trotty
Mate thanks for the reply I just done the drive shaft and bearing I'll go buy 2 new tyres and see how that goes
- x 3280
Before buying tyres try swapping them to the rear (as Dustysweeper did). That way you may not spend money until you know that is the cause.
Trotty
That's to whom replied to me I appreciate the advice I tried rotating tyres didn't mate any difference at all
darbuck
- x 290
It could be your diff or gearbox try changing the oil in the gear box.
Darren
Steve Walsh
- x 515
Just a thought
I have followed numerous cars with under trays and other parts that start flapping about at speed, Including a mate of mine that was sure his wheel bearings had gone, Have a good look underneath for anything loose that might be affected at speed.
Steve Walsh
- x 515
darbuck
- x 290
