Nemo Broke down again auto gearbox issue
ohspecial1
Unread post by ohspecial1 »
Hi folks
Semi auto so yes manual gearbox with electronics
Stopped at lights into nutral and automatic trans fault
ohspecial1
Re: Nemo Broke down again auto gearbox issue
Seems to clear if restart the car and put into manual mode
x 6956
It really needs a diagnostic and them pop the fault codes up here.
ohspecial1
Well will be putting into garage tommorow but they are saying its intermittent as they had it couple of months ago cleared the codes and it went on
ohspecial1
can i ask are these gearboxes just total crp not even 30k on the clock
x 6956
Yes, avoid like the plague. Stick to a manual or a proper automatic with torque converter. These things are a PITA when they play up and because of their nature can be expensive to troubleshoot.
ohspecial1
Well
Will find out tommorow the local garage has said if it needs any gearbox or actuators its to the dealership as it all needs programming
Just wondering if i run it until it dies
Will the manual side be affected
x 6956
Yes, because at some point if the hydraulic actuators that operate the clutch and undertake the gearbox changes fail for whatever reason, then you won't be able to drive the vehicle.
ohspecial1
Codes the same
P1394
U1213
PO750 READING THIS SOLERNOID
Doo
(Donor 2022)
x 121
Unread post by Doo »
ohspecial1 wrote: 03 Jul 2023, 19:35 can i ask are these gearboxes just total crp not even 30k on the clock
My wife's 07 C4 is almost on 100k and my 12 late Berlingo is at 159k. Both with the piloted box and the only hassle we had was when my wife's car started jumping into gear when the engine was started cold. It stalled immediately, then you could star it and away it went. It took a while to find the cause*, but as I suspected, these boxes don't have a neutral, but rather electrically dip the clutch and select 1st at shut off/start up. The throttle then allows the clutch to be feathered until you are rolling. It's actually quite clever and simple set up, but relies n the sensors.
*The cause appears to have been the crank seal weeping & allowing oil to contaminate the clutch. It finally came to the point I had to change the clutch, but then other nonsense started (injectors wuldn't come out after a glow plug broke & we needed the head off).
Anyhoo, back to your issue. A coil misfire or short circuit "can" cause issue, which is likely why your second error, U1213 is flagging up. The CanBus system requires absolute clean signals and a steady voltage. I would test the battery & the alternator to see if there is any disparity in voltage, charge output and terminal clamps are tight. A slipping belt also caused us some issue recently. U1213 is an ABS/ASC parity/toggle bit error, which basically means the signal from the ABS system is being corrupted. We had an ABS system fault which caused limp home and/or no drive. In my case, the Berlingo had a bad sensor. But I have experienced ABS error with a worn wheel bearing. At 30k I wouldn't neccesarily imagine a worn bearing, but with the sh!t state of the roads threse days, I wouldn't rule it out. I have also seen damaged or cracked reluctor wheels (the toothed rotor that the sensor reads creats a magnetic field which then collapses, it's basically a Hall Effect system) that are caked in rust and catching the sensor.
A few things to check. I cant see why the garage would be suggesting a new box at 30k. Seems someone isn't entirely clued up on these boxes.... Took me a while, but loads of reading and a good bit of personal experience has given me a respect for the system. My latest fun was her C4 and brakes not bleeding :roll: I have now bled the system 6 times and still only got an 80% pedal. However, it's sufficient to drive safely & all the systems function. But can I get the bleedin air out? Not yet, but I will.... :lol:
Has anyone seen the plot? :?
ohspecial1
Hi Well the nemo doesnt have abs not in 2010 model
And the Gearbox is totally crp and mostly only makes 70k
So with having to go to dealership
I would have thought your talking 4k plus not worth it
x 6956
You do have ABS, but you don't have ESP (Electronic Stability Programme).
ohspecial1
Have u known a bad battery to cause any of this issue
I dont mind going out and buying a battery on a chance
x 6956
No further info on those faults which I think I may have advised of previously, unfortunately.
So whether the ABS ECU is sending incorrect speed info to the gearbox ECU that is preventing it from changing gear, I can't say.
Regarding your battery - of course a weak battery can affect systems that rely on a certain voltage to operate, but given the lack of info as to whether this is responsible I can't say. Whether you can try a BSI reset (BSI Reset / Battery Disconnect / Reconnect Procedure) and see if that helps temporarily, again I can't say, but won't make anything any worse. You could have the battery health checked. If you are getting 14.3+ volts into the battery when the vehicle is running, then I can't see that this is going to cause the issue to be honest.
P0750: Gearbox fault - The gear does not engage: Not characterised
P1394: Gearbox ECU fault: Cruise control / speed limiter off request (from the gearbox)
U1213: Information fault emitted by the ABS ECU: Coherence
ohspecial1
Hi thanks Marc
Been to many gearbox people and seems they wont touch it with a barge pole
Its more do i drive it until it is un drivable or do i spend getting it sorted
I was shocked at 29k milage i expected like 60-70k
