3008 2.0 hdi shudders when letting off accelerator
Wezza140
Unread post by Wezza140 »
Hi peeps I'm.new to the site so please bear with me
I have 2010 3008 2.0 hdi automatic woth the dw10cted4 engine I'm currently getting a strange what I can only describe as an engine shudder when I left off the accelerator at speed or shall I say under boost if I drive 1st 2nd all the way up to 5th its fine I'll accelerate to over take or speed up in 5th or 6th and I can feel it start to shudder if I let of the accelerator it's shudders through the whole car I can mimic it by on and off the accelerator continuously and it will do it some days it wont do it at all🤷🏽???has anybody experienced this before and managed to cure it
I have diagbox and no faults found all readings I.e injectors egr turbo boost etc are within the limits
All help greatly appreciated 🙏
northrol
Re: 3008 2.0 hdi shudders when letting off accelerator
Unread post by northrol »
Have you checked the MAF and MAP ? I had an similar issue on another brand of car and in that case it was the MAP sensor.
Wezza140
No faults found with anyting but been replaced anyway
x 8106
Have a look at your engine and gearbox mountings, sometimes when you transist from engine pulling to engine braking you can get judder if a mounting is iffy! Just a thought! :)
willnz
x 3
Unread post by willnz »
mickthemaverick wrote: 02 Jul 2023, 10:43 Have a look at your engine and gearbox mountings, sometimes when you transist from engine pulling to engine braking you can get judder if a mounting is iffy! Just a thought! :)
In particular the engine stabilising mount under the motor on the RHS (offside).
Ladycool
New User
Unread post by Ladycool »
Ive got a 3008 Hdi sport auto, 2010 reg.
I have a shudder when taking off in 1st gear, after that it runs fine . It’s strange it doesn’t happen all the time.
However on using the Topdon diagnostic machine it’s showing a slip in placing it in auto/1st gear .
This sounds did costly , I think probably a new clutch, I’ve heard this is a big job to do ?
Other gears fine, it’s smooth acceleration is great etc turbo sound.
