C8 Vacuum Hose
- x 1083
C8 Vacuum Hose
Hi Marc, this could be tricky, but can I have a diagram of all the vacuum hoses/systems in the engine bay please.
Champion of Where's CitroJim
- x 6947
Re: C8 Vacuum Hose
Designation
" a" Yellow colour identification on the rubber pipe supplying the inlet air heater meter.
Flow Chart
(1) vacuum pump.
(2) Brake servo (ISOVAC).
(3) Butterfly housing control proportional electrovalve.
(4) Butterfly housing meter.
(5) Inlet air heater control proportional electrovalve.
(6) Inlet air metering device-heater.
(7) Vacuum reservoir.
(8) Turbocharger capsule valve proportional electrovalve.
(9) Turbocharger capsule valve.
(10) "Swirl" control electrovalve.
(11) "Swirl" diaphragm.
(12) EGR valve vacuum proportional electrovalve.
(13) EGR valve.
(14) Vacuum pipe linking the "Swirl" electrovalve to the "Swirl" diaphragm.
Connections of the unions on the electrovalves ( 3), (5), (8) and (10):
N.B.: The pipe ( e) should be connected facing the colour reference "c" on the electrovalve "b".
Connection of the unions on the electrovalve ( 10):
N.B.: The pipe ( 14) should be connected facing the colour reference "g" on the electrovalve (10).
Flow Chart
(1) vacuum pump.
(13) EGR valve.
- "b" Control proportional electrovalve
- "c" Colour reference on the electrovalve
- "e" Electrovalve outlet pipe with colour reference (at "d")
- "f" Electrovalve inlet pipe
| Reference | Designation | Electrical connector | "c" "d" | "f" |
| (3) | Butterfly housing control proportional electrovalve | Black | White | Without |
| (5) | Inlet air heater control proportional electrovalve | Blue | White | Without |
| (8) | Turbocharger capsule valve proportional electrovalve | Grey | White | Without |
| (10) | "Swirl" control proportional electrovalve | Blue | White | Without |
- "g" Colour reference on the "Swirl" electrovalve
- (14) Vacuum pipe linking the "Swirl" electrovalve (10) to the "Swirl" diaphragm (11)
| Reference | Designation | Electrical connector | "g" | (14) | "f" |
| (10) | "Swirl" control electrovalve | Black | White | Without | Without |
- x 1083
Re: C8 Vacuum Hose
How's the hoses diagram looking?
- x 6947
Re: C8 Vacuum Hose
You'll have to be more specific - this is a 'Diagram' of the vacuum system as you requested Ryan.
What exactly do you want if not this? EGR Piping, Turbo Piping, Brake Servo???
- x 1083
Re: C8 Vacuum Hose
Every vacuum pipe going please, I'm thinking turbo pipes first. I think I have a major leak somewhere. I'd rather find it by hand rather than opening a blow torch propane tank to find the leak, I like my eyebrows
- x 6947
Re: C8 Vacuum Hose
| Air Distribution Chamber | Turbo Air Piping |
| EGR Circuit | Intake Manifold Air Distributor |
| Oil Decanting / Breathers | Brake Servo |
Brake Vacuum Pump
- x 1083
Re: C8 Vacuum Hose
Thank you. That info is invaluable to me, once again you've came up with the goods!!! Honestly, your a legend
