APro
Unread post by APro »
I am looking for a replacement for the valve rocker arms for this vehicle
Vehicle : Citroen C5 (X7) 2.0 HDi
Thanks!
x 1487
Part no 0903J4 - seem to be the same exhaust and intake. £42.97 each in the UK....!
508Allure
x 5
Unread post by 508Allure »
Hi Marc,
Figured it best to just put these in one post, so thank you very much in advance for your help:
Is either 60 or 90 in the attached diagram a bumper fitting kit and if so, may I have the part number please?
I am also trying to identify the part number for the bracket which attaches the drivers side bumper to the wing (maybe no.72) and any bolts/clips this might require? Assuming I am using the correct diagram for the bumper attachment related parts?
Also the bracket and bolts/fittings which attaches/secures the underside of drivers side LED headlight to the bumper please? Can't see anything in the attached diagram (the only one I have) but I suspect such a thing might be shown with the headlights diagram.
Bonnet switch part number please (alarm occasionally goes off even prior to bump), so I suspect it requires replacement?
As shown in the attached image, it was a very light impact to the area where the drivers side bumper joins the wing, which has resulted in a gap between the two plus a loose headlight.
If you are able to post diagrams for headlight and drivers wing related parts, that would be most welcome in helping to ascertain what I need?
Many thanks.
x 6957
(60) MUL) FIXING SET (FOR FIXING FOGLAMP, SIDE TRIM, FAIRING), part: 1617975480, £23.45
(90) (MKT) FRONT BUMPER FASTENINGS (KIT COMPLET), part: 1637850580, £81.28
(72) is actually a rivet, I think you mean (24), which is the FR BUMPER AIR INTAKE RR DUCT, part: 9811359480, £78.37
There are loads of bits, so I'd need to know what you require from the above.
(7) is the Light Support Unit, part: 9800554780, £21.44
(5) Alarm Breaker, part: 6680Y4, £75.42
(but likely will be the actual Siren (2), part: 9677756080, £151.86 when the battery runs low.
Dustysweeper
x 20
Unread post by Dustysweeper »
Good evening. Looking for part number for inner and outer steering rods (both sides) for VF7**************[VIN obfuscated, can be read by forum staff] Also top strut mounts, shock absorbers, and springs for the front end.
Many thanks.
Duncan.👍
x 6957
(1) Front Suspension Damper
OEM Original, part: 1628564280, £124.62
+ Spacer, part: 9800965480, £0.80
Cheaper Alternative, part: 1635532480, £89.44
(2) Shock Absorber Rod Protector, part: 9678782580, £
(3) Shock Absorber Bracket, part: 9800479780, £69.11
(4) Nut, part: 503615, £4.99
(5) Screw, part: 9674550680, £2.44
(6) Front Suspension Protector, part: 9801094780, £2.12
(1) Front Suspension Spring (must be replaced in pairs of the same type)
Either part: 9801945380 (1 Orange + 1 White + 1 White), £117.66
Or alternative part: 9823915180, £161.17
Or
Part: 9801945480 (1 Orange +1 White +Blue), part: 9801945480, £140.50
Or alternative part: 9823915280, £161.17
(2) Front Suspension Cup, part: 9817592480, £37.03
(3) Front Suspension Bump Stop, part: 9831145480, £22.57
(4) Front Suspension Bumper Spacer, part: 9800965480, £0.80
(5) Shop Absorber Rod Protector, part: 9678782580, £8.47
(6) Cup, part: 9806642780, £8.47
(7) Cup, part: 9678749180, £5.33
(3) OEM Steering Connection Rod Kit, part: 1610817680, £63.44
Cheaper Alternative, part: 1682730480, £23.44
Orbit Motors
x 19
Unread post by Orbit Motors »
Hi Marc
I'm after numbers of any special tools to remove the front suspension spheres to enable replacement of the front suspension unit.
Also after the following:
Front lower wishbones (and ball joint numbers separately)
Rear drop links
Many thanks!
Cheers,
Miles
Satisfaction guaranteed or your dent back!
If it just about starts and drives, I'll probably buy it.
1995 Peugeot 306 XLd
2007 Citroën C6 Lignage
2003 Saab 9-5 3.0 V6 TiD
x 6957
(6) OEM Wishbone Left, part: 9663980880, £581.84
(Must also replace washer, parts: 352511, £10.52 & 352512, £10.52 do not refit originals),
Cheaper Citroen Alternative Left, part: 1682733380, £351.25 (same info & parts regarding washers as above)
(6) OEM Wishbone Right, part: 9663980980, £548.98
(Must also replace washer, parts: 352511, £10.52 & 352512, £10.52 & 352512, do not refit originals),
Cheaper Citroen Alternative (Right)Part: 1682733080, £331.39
(3) Front Wheel Hub, part: 330780, £95.58
As for the sphere removal tool, they have this as a spanner attachment, part: 9972CH, £91.86, but not sure if you can buy it from them - so a standard chain type tool may do if it's big enough to go round the circumference.
Orbit Motors
x 19
Is there a number listed for parts (8), (11) and (18) please? Trying to find the bush on its own (number 8) but there are some coming up that look like they are part 11.
Cheers,
Miles
x 6957
Here you go Miles:
(8) Wishbone Arm Mounting, part: 3523AQ, £27.58
(11) Wishbone Arm Mounting, part: 3523CA, £18.24
(18) MUL Flanged Bolt, part: 364818, £3.29
naragorn
Unread post by naragorn »
Hi, I would appreciate if you could share with me the number parts for the front and rear brake pads for a Peugeot 308 2017. VIN: VF3**************[VIN obfuscated, can be read by forum staff]
x 6957
@naragorn: Read the first post here:
viewtopic.php?t=69962
naragorn
GiveMeABreak wrote: 09 Jul 2023, 11:33 @naragorn: Read the first post here:
Sorry I didn't read it. I've updated my status now
x 6957
No worries,:-
Front Pads
(3) Set of 4 pads (Genuine Citroen), part: 1647860280, £124.08
Set of 4 pads (Cheaper Citroen Alternative), part: 1619790980, £47.94
Rear Pads
(2) Citroen Original Brake Pads, part: 1636413980, £105.58
Citroen Cheaper Alternative, part: 1619790880, £67.44
All direct from Citroen and include UK 20% VAT
naragorn
Thanks for the prompt reply! Have a nice day
