Peugeot 5008 abs fault
paulgregory10
x 5
Unread post by paulgregory10 »
Hello all I am working on a peugeot 5008 with a wheel sensor issue, I have changed the LH Rear wheel sensor as indicated in diagbox and fault still exists so looking for a wiring diagram and connector locations for a peugeot 5008 vin VF3**************[VIN obfuscated, can be read by forum staff] thanks 😊
x 6956
Re: Peugeot 5008 abs fault
That VIN is invalid and the last 8 digits bring up a Peugeot Partner.....
paulgregory10
x 5
Ok mark the not sure if the 5 might be an s hence VF3**************[VIN obfuscated, can be read by forum staff]
x 6956
Nope, that's not it either. :?:
If you're having trouble reading it, take a photo of the VIN on the lower windscreen corner and PM it to me.
paulgregory10
x 5
Thanks Marc sent photo as requested 👍
paulgregory10
x 5
Haha 😄 just seen raindrop makes the 0 look like a nine. Need new glasses
paulgregory10
x 5
Vin VF3**************[VIN obfuscated, can be read by forum staff]
x 6956
It may help if you can supply the actual fault codes to Paul.
Many of the hardware codes are on the wiki:
https://frenchcarforum.co.uk/wiki/Elect ... ring_Codes
paulgregory10
x 5
Thanks Mark, will update later off to work now qiring diagram helps alot thanks
lawns
x 3
Unread post by lawns »
Hi paulgregory10, do not know age of your car but my 2011 3008 has had problems on all four sensors over the years with corrosion on their mounting pushing the the sensor away from the pick up ring or even into the ring and causing damage to it. May be worth a good clean up and inspection first.
paulgregory10
x 5
Hi all fault was a broken wire coming over the axle to the wheel sensor all sorted now thanks to all👍
x 6956
Great, thanks for the update.
