- x 6955
(1) Original OEM Turbo, part: 0375C8 no longer available.
Exchange Turbo (Garrett), part: 0375F2, £707.18
(2) Turbo Supp Bracket, part: 037753, £45.16
(3) 116438 Turbo Lubrication Pipe, part: 116438, no longer available
(4) Turbo Oil Return Pipe, part: 037933, £55.55
(5) Outlet End Peice, part: 038325, £110.12
(11) Turbo Lube Bolt, part: 116446, £12.94
(12) Copper Seal, part: 038021, £0.79
(13) Oil Return Tube Seal, part: 038033, £2.96
(20) Turbo Lube Oil Filter, part: 1611517480, £4.00
Any other bits let me know.
quintet
- x 44
Thank you for that, i have a few options now, some recon, some just second hand turbos and most of the other bits seem readily available.
Music keeps me going.
- x 1061
Okay Marc, time to put your brain to the test! Can you supply us C8 drivers with an exploded view of the swirly thingy majic,....thx in advance
Champion of Where's CitroJim
- x 6955
@Rp0thejester: ?
If you mean the EGR, there's nothing further than what I have already put up previously on the part request response earlier.
- x 1061
No, not that part, the swirly thingy majic part which is attached to the block near the intake manifold
- x 6955
Intake Manifold Air Distributor
(12) Diaphragm, part: 036394, No longer available.
(15) EGR Solenoid Valve, part: 1628CH, no longer available
- x 1061
Thank you, is there a diagram that is breakable in that part?
- x 1061
*diaphragm
- x 6955
It's a complete unit.
You can get them here Ryan:
https://eurofrance24.com/air-throttle-b ... 8-807.html
- x 1061
If I wanted to buy part 15 from somewhere else, it's available then?
- x 1061
Just seen your post Marc, thx
- x 6955
Yes, just Google the part numbers I've supplied - plenty of aftermarket choices. When I say 'no longer available' it just means not from Peugeot.
tearing hair out
- x 19
Hi. I'm almost certain my EGR value, etc, part numbers are the same as Rp0thejester's, so I don't think I need part numbers. However, is there any data on the expected performance of various emission control components - opening position vs engine conditions, say - for things like the EGR valve and other parameters that are tracked by Lexia, please? Or, indeed, diagnostic steps to troubleshoot it?
If so, they might make more sense on this post (or maybe here and there): viewtopic.php?t=75116
Citroen C8 2.2HDi, VF7**************[VIN obfuscated, can be read by forum staff]
Thank you.
Thank you.
Paul
I would have more Citroens if I had the space...
tearing hair out
- x 19
Oh, in fact a part number for the fuel cap presence sensor would also be of interest, I think, please.
Paul
- x 6955
@tearing hair out: Not fitted to your vehicle
