- x 6946
I don't know what other seal you are referring to, but this is the other diagram of the crankshaft balancing, but I can't see any seal:
Timing Belt Kit replacement: every 112000 Miles / 10 year(s) on this engine. However regular checks of the belt should be made during routine servicing to ensure the belt is conforming - otherwise it may have a warranty claim if the vehicle is less than 6 years (72 months) old and has a mileage of less than 100k kms (62k Miles).
- x 1942
Isn't number 5 on the previous diagram the rear seal?
- x 1496
Item 2 I think (5 is the bolts...)
Reference Description Quantity Price - VAT Price + VAT Total + VAT
1611187480 CYLINDER HOUSING GASKET PLATE 1 61.92 GBP 74.30 GBP 74.30 GBP
- x 1942
I meant 2. Finger fumble problem when using a phone.
- x 1080
Could I get the part number for the egr valve on my C8 and also a diagram of how to find it in the dark dingy engine bay please.
Champion of Where's CitroJim
- x 6946
(15) EGR Valve, part: 1628XP, no longer available from Citroen Ryan.
Shown at (3) above ^
- x 1080
Thank you, just what I feared, a horrible place to get to
- x 1080
In the very bottom left corner of the parts diagram is there a gasket that needs to be there?
- x 3296
Item 16?
- x 1080
I'm looking at just above 84 X, bottom left as I have a metal gasket between the two
- x 6946
The EGR Seal must be replaced and is item (16). Kits should come with the seal.
- x 1496
Difficult to see, I think it connects onto the inlet manifold? There is no gasket shown there either, oddly. 84 is just the bolts.Rp0thejester wrote: 13 Jun 2023, 20:01 I'm looking at just above 84 X, bottom left as I have a metal gasket between the two
earlsgate
- x 6
looking for the Rear Shock absorber OE part number for my Boxer 2017 435
thanks martin
thanks martin
- x 1056
Here you go, not sure why there are 2 different aftermarket alternatives thoughearlsgate wrote: 15 Jun 2023, 09:20 looking for the Rear Shock absorber OE part number for my Boxer 2017 435
thanks martin
5206VC was the original part no but they have been updated to the numbers below.
quintet
- x 44
Hi, could i please get the part numbers for a turbo, both it's oil pipes and any associated gaskets. As i understand my vehicle has the later spec but in an early body, for reference it has no doser valve in the air inlet pipework. For additional clarity the RP is 1033489 VF3**************[VIN obfuscated, can be read by forum staff]
I have the prices from the dealer, a new one is no longer available but a recon is but it's pushing £1000 with the surcharge & vat, not inc pipes and gaskets & then it'll need fitting..... so i'm just trying to find a cheaper one online somewhere but there's a number of variations & few people seem to have them for the 90hp engine. Thanks in advance.
Music keeps me going.
