x 1047
Unread post by wheeler »
Orbit Motors wrote: 05 Jun 2023, 00:19 Good morning,
After some bits in the vicinity of the offside front brakes.
- The bolts securing the brake caliper bracket to the steering knuckle
- Brake hose
- Caliper itself (probably won't need one but useful to have a part number just incase)
Also after a number for the instrument cluster bulbs that do the main lighting for the drivers info and speedo.
Many thanks in advance
- The bolts securing the brake caliper bracket to the steering knuckle 440547 £3.67 + V
- Brake hose original 480685 £41.81 + V aftermarket 1623254380 £13.44 + v
- Caliper itself (probably won't need one but useful to have a part number just incase) 1617292180 (new) £161.58 + v (exchange) 441068 £81.30 + v
Also after a number for the instrument cluster bulbs that do the main lighting for the drivers info and speedo. Bulb with holder 611256 £5.90 + v
x 6961
Orbit Motors wrote: 05 Jun 2023, 00:19 - The bolts securing the brake caliper bracket to the steering knuckle
- Brake hose
(2)
Citroen Original Front Brake Caliper (Left), part: 1617292080, £199.10
Citroen Original Front Brake Caliper (Right), part: 1617292180, £193.90
Cheaper Exchange Caliper (Left), part: 441067, £97.56
Cheaper Exchange Caliper (Right), part: 441068, £97.56
(10) Brake Caliper Fixing Screw, part: 440547, £4.40
(16) Brake Hose Front
Citroen Original (Long 483), part: 480685, £50.14
Citroen cheaper alternative, part: 1623254380, £16.13
(10) Bulb Holder, part: 611256, £7.08
Prices inc. VAT and are direct from Citroen. Prices can fluctuate daily and marginally from dealer to dealer.
Note: calipers require a deposit, refundable on return of old part.
dwjlivermore
Unread post by dwjlivermore »
Afternoon all
I’d be very grateful if someone could provide the part numbers for the following
Cruise control stalks
Radiator cooling fan
Rearmost plastic side trim on passenger side (horizontal plastic trim just forward of the rear left wheel)
For VF7**************[VIN obfuscated, can be read by forum staff]
Many thanks
Darren
x 6961
Hi Darren
The cruise control stalks are not available separately - only the complete module:
(1) Multifunction Control Unit (Marking Y735536957), part: 1640623680, £328.45
I've included the resistor and relays in case that's all you need to fix it)
(1) Fan Motor Kit, part: 1671210080, £625.34
(5) Fan Additional Resistor, part: 1267J7, £35.75
(6) Electric Relay, part: 1237J8, £41.53
Let me know which item (if any) you need the part number for the trim above.
dwjlivermore
What a truly wonderful service you are offering. I’m blown away! Thank you. Number 32 please.
Best regards.
Darren
x 6961
No problem
Item (32) Rear Wing Protector (Left Side), part: 8547X1, £79.45
danlat1415
x 24
Unread post by danlat1415 »
Hello, please could you let me know the windscreen washer filler neck? (top part)
I think it's 9676606580 but want to check first. Mine is heavily stained and discoloured.
VIN - VF7**************[VIN obfuscated, can be read by forum staff]
x 6961
Hi Dan
Item (2) Filler Pipe is part: 9676606580, £11.35
stevelp101
Unread post by stevelp101 »
Hi. Would like to see the part numbers & sizes of the front discs and pads. Are they still available for order?
Also I would probably change some of the easier parts like the link rods. do you have a part number for them too?
Ah! also the calipers too!
Many thanks.
Steve
x 6961
Original Genuine Citroen parts are no longer available for these items Steve, but the Citroen alternatives are, so these are the parts for those.
Drop Links
(5) Left / Right, non-adjustable part: 1634874780, £21.83 each
Discs / Pads
(2) Citroen Cheaper Alternative Front Disc, part: 1618863380, £58.67 (each as far as I can tell)
(3) Citroen Cheaper Disc Pads, part: 1617280380, £46.31
All available from Citroen direct, inc. VAT
jac
(Donor 2021)
Unread post by jac »
Hello,
Looking for a replacement A/C condenser pump part number please? Is there a seal kit that is needed or anythign for fitting these?
Many thanks!
x 6961
(1) Condenser, part: 9816746580, £503.10
Narl
x 4
Unread post by Narl »
Looking rear crankshaft oil seal & timing belt kit (pulleys, tensioners, etc)
Thanks.
x 6961
(4) Crank Seal, part: 9835304280, £38.34
The timing distribution kit will vary on parts, depending on part number of the gauge (orange or yellow), so I've listed all the possibilities:
(13)
OEM Distribution Kit, (WITH GAUGE PART NUMBER 9816715980 ORANGE), part: 1654516080, £198.32
Cheaper Peugeot alternative, (WITH GAUGE PART NUMBER 9816715980 ORANGE) part: 1686354380, (£ Not showing price so may not be available)
Timing Tensioner Roller (WITH GAUGE PART NUMBER 9809038580 YELLOW), part: 1654508980, £92.08
Narl
x 4
Is there a rear crank seal?
Also the timing belt schedule 6 years / 100k?
