x 6956
@Rp0thejester
DPF
(12)
Original New OEM Octo Square DPF, part: 1731NG, £924.52
Standard Exchange Particle Filter, part: 174035, £1205.78
Cheaper DPF, part: 1611323580, £737.93
Exhaust
(1)
New OEM Intermediate Pipe, part: 9677343880, £146.54
Cheaper Alternative, part: 1607337480, £115.30
mrhardware
(Donor 2022)
x 4
Unread post by mrhardware »
Hi Marc
I am looking for the part number and price for a replacemnet tailgate washer pipe for my C5 X7.
Also the part number for the replacement white clips that hold the tailgate surrounds in place.
The flexable part that goes between the tailgate and body.
Thanks in advance.
Mark
x 6956
(12) Window Washer Pipe, part: 6439J3, £68.89
(13) Window Washer Pipe, part: 6439J4, £22.34
(14) Window Washer Pipe, part: 6439J5, £14.99
(51) Wiring Sheath, part: 6439J6, £18.02
(70) Pipe Fastener Clip, part: 5280R4 (No Longer Available)
Let me know if there's anything missing.
Jay-Bruce
x 282
Unread post by Jay-Bruce »
Hi Marc, can you check the price & availability / lead time of the O/S (right) driveshaft for our C5 3.0hdi, I believe 3273WF is the part number cheers /Jay :-)
x 6956
Hi Jay
That's the wrong part number. :wink: (3273WF is for a Petrol C3 incidentally)
(02)
OEM Original Citroen Driveshaft (Right), part: 3273WY, £597.73
Citroen Exchange Driveshaft (Right), part: 3273WZ, £352.06
There's a £72 (inc. VAT) refundable deposit on the Driveshafts (new or Exchange). Can't give you a lead time, but the dealer should be able to advise.
Jay-Bruce
x 282
Thanks Marc, does the system have any dimensions for the shaft, such as length overall and or length from bearing to tip of splines?
x 6956
No, sorry Jay, not specified.
Jay-Bruce
x 282
Fair enough, it's a bank holiday up here, so I'm going to have to wait on getting hold of a dealer, but had started looking at other channels, and there seems to be a lot of confusion with sites like Autodoc / eBay sellers on what shaft is right for a v6, I'll call the dealers in the morning, see what the lead time is. Cheers /Jay
508Allure
x 5
Unread post by 508Allure »
Hi Marc,
Would it be possible to get the part numbers for rear discs and pads plus pad wear sensors if applicable?
x 6956
Rear Brakes
(1) Rear Discs
Citroen OEM Disc Kit (DIAM 268 EP 12), part: 1609582880, £138.08
Cheaper Citroen Disk Kit, part: 1642776380, £78.82
Cheaper Citroen Disk Kit, part: 1687772580, £98.28
(2) Rear Pads
Citroen OEM Rear Brake Pad Repair Kit, part: 1609000680, £89.47
Cheaper Rear Brake Pad Kit, part: 1619790880, £67.44
There are no sensors for pad wear on the rear brakes, so assume you mean this as the rest of the parts are for the rear.
508Allure
x 5
Hi Marc,
I don't suppose you know the part number for the drivers side equivalent of this part number please?
9814255780 (No.50 in the attached image)
It's a headlight mounting repair kit but I am after the drivers side kit and any other repair kits they offer for the LED headlight.
Thanks.
x 6956
(50) Headlamp Repair Bracket
(Left), part: 9814255880, £79.96
(Right), part: 9814255780, £79.96
mrhardware
(Donor 2022)
x 4
Hi Marc
please can you help , i am looking for the part number and price for the near side windscreen wiper motor for my c5 x7.
Ive got a motor stop error on the unit in the car.
Thanks in advance.
x 6956
Here you go:
(2) Left (UK Passenger Side) Wiper Motor, part: 6405LE, £430.02
Orbit Motors
x 20
Unread post by Orbit Motors »
Good morning,
After some bits in the vicinity of the offside front brakes.
- The bolts securing the brake caliper bracket to the steering knuckle
- Brake hose
- Caliper itself (probably won't need one but useful to have a part number just incase)
Also after a number for the instrument cluster bulbs that do the main lighting for the drivers info and speedo.
Many thanks in advance
Cheers,
Miles
Satisfaction guaranteed or your dent back!
If it just about starts and drives, I'll probably buy it.
1995 Peugeot 306 XLd
2007 Citroën C6 Lignage
2003 Saab 9-5 3.0 V6 TiD
