c4 picasso ABS/ESP and Parking bracke fault.
- x 6948
Re: c4 picasso ABS/ESP and Parking bracke fault.
The wires may 'look' good, but in order to check them, you really need a CAN Break Out Box to check the them.
C4apolo
Yes problem sloved. I disconnected the pneumatic suspension ecu. and everything works, ABS/ESP and handbrake. only suspension fault is still shown on the display. maybe it can be turned off somehow so that it doesn't exist. BSI is disabled, but the display shows nothing.
Thanks for help.
Thanks for help.
C4apolo
one small problem remains though. if the car stops for a while and the blocks go to sleep and then turn the ignition key and start, then a brake error is displayed and only ESP lights up, but when you turn off the ignition and start the car again, everything works and there are no errors. Couldn't it be related to when the BSI unit is looking for the air suspension ecu? how to fix it
- x 6948
You may need to configure the BSI to ensure that Pneumatic Suspension and suspension ECU is absent - there may be several areas where this is mentioned.
C4apolo
All this to be done only in BSI block? I looked at BSI, it says ABSEND or no present everywhere. maybe i missed something
- x 6948
Check for 'Height corrector', Suspension ECU etc and set these to absent.
C4apolo
nothing is shown about the air suspension. but the problem remains and after a long time when the car is stationary. when waking up, an error appears in the electric handbrake. U2219 and U1313, if the car does not go to sleep, the errors do not appear. Could it be when the battery needs to be changed? because when diagnosing the car, the economic mode wants to go
- x 6948
| Fault Code: | U1313 |
| Description of Fault: | Fault in the reception of the partial triggering message by the built-in systems interface (BSI). The dynamic stability control ECU causes functional faults. Conditions of activation of the diagnostics Ignition on. |
| Conditions for Fault to clear: | Reception of 3 consecutive items of valid information |
| Downgrade Modes whilst Fault is active: |
- "a": Lit - "b": Not on - "c": Lit |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | U2219 |
| Description of Fault: | Fault in the transmission of the message concerning the partial wake-up by the electronic parking brake: Coherence. Transmission of invalid information. |
| Conditions for Fault to clear: | - |
| Symptoms: |
| Suspect Areas: |
Economy mode will kick in if the battery is detected as being weak, so I'd make sure it is charged up to eliminate issues. ECUs will show faults if there is insufficient voltage.
C4apolo
the most interesting thing is when the car does not fall asleep, then everything works and there are no errors. If the car stops with the ignition off for 2 minutes, when you turn the ignition it shows when the brake is faulty. and these errors U1313 and U2219 turn off the ignition and turn it on again immediately, then everything works. if there was a can line, then I wonder when it won't work at all. all about awakening.
about the can line there is an error in the motor control unit U1118 and U1318. maybe you need to calibrate the abs sensors and the steering angle sensor, but why does turning the ignition key twice everything works, it's interesting
