x 6945
Here you go:
(11) Cage Screw (8X125-25), part: 150281, £4.06
x 1052
Unread post by wheeler »
Thats the alarm siren 👆🏻
x 6945
Sorted, Ta.
dylan26__
x 22
Unread post by dylan26__ »
GiveMeABreak wrote: 20 May 2023, 18:40 Here you go:
Oh thats weird! on my car the nut (10) is welded to the bracket on the car and then the bolt (11) is a 10mm with a big washer stuck on it. really fine weird thread kinda like in the picture. Is there any other configurations? it's a stock setup and not been changed since factory so i'm not sure why it's a bit different on the diagram
looks a lot like this: https://prnt.sc/39FsN8hxsL8F
dave101ua
Unread post by dave101ua »
GiveMeABreak wrote: 17 May 2023, 16:26
You have several options, depending what you require:
(6)
OEM Citroen Passenger Compartment Filter (carbon / Gas), part: 6447XG, £49.04
Cheaper Passenger Compartment Filter (carbon / Gas), part: 1609998880, £27.78
Premium High Performance Carbon / Anti Allergenic, part: 9821501880, £61.22
Thank you!
rtakah
Unread post by rtakah »
Can I please get the vehicle characteristics from VIN VF7**************[VIN obfuscated, can be read by forum staff].
It's a whisper violet DS3 and I'd like to confirm which type of seat came standard on this car, fabric or leather and whether it had heating or not.
Thank you!
x 6945
Ok, so the build specs. won't tell you this, as it depends on the trim level and options as to what was fitted to each individual vehicle at the time of order. So in other words your VIN will only tell you what your vehicle was fitted with.
You don't have heated seats and your colour / type is listed as 'AKINEN G116+ALC F227+OMNI F942 ’3S’'.
Other options were:
  • BRAID CAPCOVE G113+DINAMICA G144’6Z’
  • CLUB LEATHER L036 "8D"
  • DINAMICAG144+SURPF090+CREPF942 OR DINAMICA GXXX/G144+OMNI F942 ’4V’
  • LEATHER ALCANTARA + TRAMI + CARLA "86" AND "FO" OR ALCANT FXX+TRAMI2 F971+CARLA ’7G’ AND "FY"
  • LEATHER CLAUDIA L019+CARLA V210 ’3U’
  • WEAVE RAYADOS G115+OMNI F942 ’3R’
  • WEAVE STURM G114+OMNI F942 ’3Q’
Trim levels change throughout the production run and include special additions, so what is actually fitted will depend on the build date and trim level at the time.
Dustysweeper
x 20
Unread post by Dustysweeper »
GiveMeABreak wrote: 20 May 2023, 08:41 Here you go:
(2) Right Driveshaft
Citroen OEM New, part: 9677916180, £485.34
Exchange, part: 1609609680, £285.384
Hi Marc. Is there by any chance any information that states the total length and how many teeth it has on each end. I've sourced one but need to know if it is in fact the correct part.
Many thanks
Duncan.
x 6945
Unfortunately not Duncan. Obviously the OEM part number would just be the correct part for this vehicle when ordering from Citroen. Aftermarket parts are not always the same as has been seen time and again here, so be wary and make sure it is an exact match for the original part number, or don't buy it if you can't be certain.
ocmil
Unread post by ocmil »
Hi
Is it possible to find out the gearbox ratios for the following vehicles using the VIN? If not, I'd be interested in the part number for the 5th gear set on the Berlingo box.
2009 Berlingo
Gearbox Code: 20DP47
2016 308
VIN:VF3**************[VIN obfuscated, can be read by forum staff]
Gearbox code :20ET13
Cheers, appreciate any help
x 6945
Berlingo 5th Gear Set:
(1) Piston Assembly, part: 2344F5 £370.68
(3) Gear Box Shaft Spacer, part: 230460, £26.16
(4) Manual Gearbox Synchroniser, part: 238804, £79.85
(6) Synchro Hub, part: 232119, £46.21
(7) Gearbox Shaft Fixing Nut, part: 230481, £7.38
(8) Gearbox Shaft Fixing Nut, part: 230459, £4.66
(9) Gear Spacer, part: 233933, £11.59
Ratios for the specific Gearbox on this Berlingo:
Stages Gearbox1st2nd3rd4th5thReverse gear
BE4/5L11/3815/2832/3745/3750/3312/40
Peugeot 308
Note, this gearbox has a different code (BE4/5 O) and ratios:
BE4/5011/3815/2835/3946/3554/3112/40
dylan26__
x 22
Hey, could i get the part numbers for the injectors please (also if it saysanything that is also related that would need replacing at the same time)
Cheers, Dylan
ocmil
Much appreciated, a huge help!
Reason: Removed Quote
x 6945
dylan26__ wrote: 27 May 2023, 21:24 Hey, could i get the part numbers for the injectors please (also if it saysanything that is also related that would need replacing at the same time)
Cheers, Dylan
You need to change the injector supply pipes when changing the injectors because the pipes are one time use only - as they form when tightened and deform when removed, so the seal is compromised.
(2) Diesel Injector Supply Pipe part: 1570P9, £15.49
(3) Diesel Injector Supply Pipe part: 1570Q0, £15.49
(4) Diesel Injector Supply Pipe part: 1570Q1, £15.49
(5) Diesel Injector Supply Pipe part: 1570Q2, £15.68
(7) New Original Continental Injector, part: 9802448680, £583.36
(7) Cheaper Exchange Continental Injector, part: 1608518380, £436.76
(8) Engine Injector Protector, part: 1982G6, £3.43
(9) Engine Injector Seal, part: 198194, £3.86
x 1072
Unread post by Rp0thejester »
Hi Marc, could I have the part number for my C8s dpf filter please. And also the pipe to back box please
