P0425 - limp mode
dpround
P0425 - limp mode
Unread post by dpround »
I have P0425, engine dropping in to serious limp mode - 30mph max and sometimes the ECU blocks cranking of the engine if stopped. I think the oxygen sensor or wiring in front of the cat may be to blame, but in this euro 5 van with the close coupled cat I can barely touch the sensor so cannot do any useful inspection of the wiring etc. Am I missing something? The access is almost too horrible to be true. It might be possible remove the cat from the engine as held on with a magic clip? Any advice appreciated.
x 6956
Re: P0425 - limp mode
You seem to be missing the last 2 parts of the fault code. Without these I can't provide the exact details. There should be a 16, 17 or 27 on the end. All these faults relate to the particle filter upstream temperature sensor and not the Catalytic converter.
P0425 16 Exhaust high temperature sensor: Voltage below the minimum threshold
P0425 17 Exhaust high temperature sensor: Voltage above a threshold
P0425 27 Exhaust high temperature sensor: Voltage variation outside the tolerance
Pop your VIN up and the last part of the P0425 code to ensure I have the exact engine management system (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff).
dpround
Excellent news. At least I can see the sensors in the dpf. Unfortunately the code has been cleared to get home. I'll try and recreate and read on a real reader this time.
dpround
I am unable to get a consistent resistance reading on the pre-DPF temperature sensor. The value I get is apparently cycling between 6 and 10M ohm with the sensor at ambient and disconnected. (The cycling bit is probably irrelevant consequence of using a DVM and low sample rate, but is oddly consistent.) The replacement pattern part shows a consistent 6M ohm. I am going to be lazy and just replace and see if the fault goes away.
dpround
Well finally found time to drive the van and it is not fixed. (It is a motorhome, so not in regular use...) The fault codes are 2428-98 and 0425-17. Probably more telling is that the pre-DPF temperature remains at 60C all the time in the live data where the pre-cat temperatures rises rapidly and believably to a few hundred C. I'm pretty confident that the fault is with the pre-DPC temperature sensor, but it may be in the wiring or ECU so is going to be a bit tougher to fix. Any hints on how you would proceed would be very welcome.
x 6956
I did ask for the VIN previously, so I can ensure the codes are correct for the engine management system you have, then I can deal with the other fault code.
dpround
Sorry Marc, my memory for detail could be better. VIN is VF3**************[VIN obfuscated, can be read by forum staff]
All the best
David
dpround
The plot thickens further. The diagnostic software (MaxiECU) Gives two exhaust temperatures, pre CAT and pre DPF. From unplugging the sensors and replacing with a short or open circuit to give max and min readings it is clear that the pre-CAT temperature is from the pre-DPF sensor and the pre-DPF temperature is from the sensor in the middle of the DPF - also loom and ECU are good, which is a relief! This means the sensor that is faulty is not the one I have replaced! I have ordered a post-DPF sensor, but it has arrived with the pre-DPF plug, so no resolution yet.
I could create a replacement post-DPF sensor from the old pre-DPF sensor and the plug from the faulty post-DPF sensor (the post-DPF sensor reads open circuit, so might really be faulty) if anyone happens to know if the sensors are based around the same thermistor.
dpround
After replacing the correct sensor, all appears well. I am hopeful that it is actually fixed this time. I could have saved a lot of time by paying more attention to the live data and using using deliberate anomaly conditions to prove I really understood what I thought I was seeing rather than relying on the fault codes. Thanks for the help :)
