I'm planning to do a clutch change on my BX diesel built in 1991.
I'm going to try the strut-trick to avoid having to undo the lower balljoint.
So in steps:
- Remove wheel / hubnut
- release hydr. pressure, unslacken strut, remove driveshaft
- remove gearbox
- change clutch
- put everything back and pray it works
My questions:
- do I have to support the gears in the diff. when removing the rhs driveshaft or is this applicable for older makes only?
- Which parts do I need besides a new clutch; what oil seals etc. are needed; Haynes confuses me a little.
Thank you in advance,
Tom Jansen
