407 washer jets
x 5673
Re: 407 washer jets
Can be hard to see and the oblong cutout is to enable positioning of the spray.
I had to take mine out periodically and back-flush them with hot water. The washer fluid filler cap had been missing and there was a lot of crap in the reservoir. Can also be algae growing in there.
Best done on a warm day as the plastic is easily broken.
When/if you remove them, pump a lot of water through the hoses to clear any muck out.
Martinez
x 19
Re: 407 washer jets
Unread post by Martinez »
Found the problem. It was pissin out the pipe near the bonnet hinge. I’ll have to pop to Halfrauds for a joiner. Tried fixing it with heat shrink and silicon, but no good, I’ll just have to cough up the cash🤪
Thank for all the advice chaps, I can confirm there is a jet. But as for removing them from the bonnet, I could only get them out by prising them out which may have broken a clip off. Couldn’t get near them from underneath. Regardless they both clicked back in again, and Mr Silicon will help out if they do come loose.
