Hi
Does anyone have a detailed service schedule for a 2015 DS3 1.6 E-HDI? The car was bought used and there's nothing in the documentation about the service intervals. I've searched online and found mention of the oil/filter interval being 12,500 miles (which seems high to me) but nothing about other jobs like brake fluid, coolant, etc.
We want to make sure the car is looked after properly, but that's difficult when the service details aren't in the handbook!
Karl
DS3 1.6 E-HDI (2015) Service Schedule?
- x 6950
Re: DS3 1.6 E-HDI (2015) Service Schedule?
Pop your VIN up for me (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff) and I'll be able to advise.
KarlF
Hi Marc
Many thanks - the VIN is VF7**************[VIN obfuscated, can be read by forum staff]
Much appreciated!
Karl
Much appreciated!
Karl
- x 6950
Here you go:
Servicing
Additional Operations
Authorised Engine Oils:
EM:05W30 B71 2290 - 05W30 B71 2290 (C2) - EM:00W30 B71 2312 - 00W30 B71 2312 (C1C2)
*Arduous conditions of use:
If you meet one or more of the arduous use conditions, special servicing will be necessary:
Servicing
| Servicing | Normal Conditions of Use | *Arduous Conditions of Use |
| Services: Systematic Operations | Every 16000 Miles / 1 year(s) | Every 10000 Miles / 1 year(s) |
| Replacement of the brake fluid | Every 2 year(s) | Every 2 year(s) |
| Replacement of the passenger compartment filter | Every 16000 Miles / 2 year(s) | Every 10000 Miles / 1 year(s) |
| Check of the PH of the coolant | 80000 Miles / 4 year(s) Then every 16000 Miles / 1 year(s) | 80000 Miles / 4 year(s) Then every 10000 Miles / 1 year(s) |
| Check of the clogging of the particle emission filter | 112000 Miles Then every 16000 Miles | 100000 Miles Then every 10000 Miles |
| Check of the particle emission filter additive level | 64000 Miles Then every 16000 Miles | 60000 Miles Then every 10000 Miles |
| Replacement of the air filter | Every 32000 Miles / 4 year(s) | Every 20000 Miles / 4 year(s) |
| Replacement of the fuel filter (diesel) | Every 32000 Miles / 4 year(s) | Every 20000 Miles / 4 year(s) |
| Replacement of the ancillary drive belt | Every 80000 Miles / 6 year(s) | Every 80000 Miles / 6 year(s) |
| Replacement of the ancillary drive belt kit | Every 112000 Miles / 10 year(s) | Every 110000 Miles / 10 year(s) |
| Replacement of the timing kit and of the coolant pump | Every 112000 Miles / 10 year(s) | Every 110000 Miles / 10 year(s) |
- Permanent door to door, Repeated short journeys (less than 6 miles) with cold engine (after stopping more than 1h).
- Urban use (such as taxi, ambulance, average speed below 12 mph, driving school).
- Engine running long or frequently in slow motion (police, taxi), intensive use (driving school)
- Prolonged period of use in:
countries with a dusty atmosphere,
countries with fuels that do not meet the manufacturer's recommendations. - Use, even occasional, of B20 or B30 fuel (Diesel vehicles) or petrol containing more than 3 % methanol.
KarlF
Excellent, thank you - that's exactly what we need.
Am I right that "Services: Systematic Operations" is the engine oil & filter change, plus general inspections?
We'll definitely change the oil & filter a lot sooner than every 16,000 miles - that seems way too infrequent given what I've read about turbo failure due to dirty/thickened oil!
- x 6950
Sort of... The systematic operations are those determined for each specific service interval. So there will be different operations / checks for both 'minor' and 'major' services as well as those time-specific additional operations listed above.
Just make sure you use the correct oil (which I have also listed above for you) as it must meet the specifications listed and be of the correct grade for the country.
