x 6945
Fuel Filter
(5) Fuel Filter
Citroen Original part: 9801366680, £51.36
Cheaper Option, part: 1643624980, £17.69
Air Filter
(2) Air Filter
Citroen Original, part: 9800097580, £34.88
Cheaper Option, part: 1638027680, £18.47
Prices UK VAT inclusive (20%) direct from Citroen.
Narl
x 4
Unread post by Narl »
Sorry. It appears there has been a few things gone.
Most major part is a crank shaft oil seal. Just looking part number if at all possible?
dave101ua
Unread post by dave101ua »
GiveMeABreak wrote: 17 May 2023, 11:10 Fuel Filter
Air Filter
Thanks a lot !
x 1053
Unread post by wheeler »
Narl wrote: 17 May 2023, 13:53 Sorry. It appears there has been a few things gone.
Front crank seal 983504280 £38.34 inc VAT
Rear crank seal/plate 1611187480 £74.30 inc VAT
dave101ua
Air Filter
One more thing,
give me also the number for the interior/cabin Air filter, please
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Thank you
x 6945
You have several options, depending what you require:
(6)
OEM Citroen Passenger Compartment Filter (carbon / Gas), part: 6447XG, £49.04
Cheaper Passenger Compartment Filter (carbon / Gas), part: 1609998880, £27.78
Premium High Performance Carbon / Anti Allergenic, part: 9821501880, £61.22
Narl
x 4
wheeler wrote: 17 May 2023, 15:33
There is a belt which is in this area. It’s not the auxiliary belt it seems to be a smaller one, I might as well replace that new to new seems to work best imo.
jamescarruthers
x 47
Unread post by jamescarruthers »
GiveMeABreak wrote: 15 May 2023, 11:25 Image
(2) Gauge with Pump, part: 9687218480, £391.04
There's a special procedure for gaining access with the rear electric seats. The procedure can be found here James:
C6 Rear Electric Seat Removing - Refitting
Marc, thank you so much. With the information you gave me I was able to get the Bosch part number and have one sent the next day for £74!
Most importantly you gave me the confidence to actually access the pump because I was convinced that taking the electric recline rear seat “lounge pack” out would’ve been an absolute nightmare but it was actually quite a simple job. I had access to the tank in an hour and it was quite straightforward with the guide. I would not even have attempted it otherwise.
1987 Volvo 480 ES
2006 Citroen C6 3.0 petrol Exclusive
mrhardware
(Donor 2022)
x 4
Unread post by mrhardware »
Hi Marc
I am looking for a part number for a replacement nearside window regulator for a C5 x7 Tourer,
Sounds like ive had a cable snap on mine.
Vin :VF7**************[VIN obfuscated, can be read by forum staff]
Do you know if the tailgate wiring loom is seperate to the mail loom or is it all in one .
Thanks in advance
x 6945
(3) Window Regulator
Left
Citroen OEM Original, part: 9675899080, £503.00 (possibly with Motor - Please check with dealer)
Cheaper Alternative, part: 1619990980, £193.86 (Without Motor)
Cheaper Alternative, part: 1689036080, £185.70 (Without Motor)
I did notice one on Amazon advertised as a genuine PSA one for £121 (with motor)!
https://www.amazon.co.uk/Electric-Regul ... B07T5KNCJN
Dustysweeper
x 20
Unread post by Dustysweeper »
It never rains but it pourers. Nothing but trouble with this box. I need the part number for front right driveshaft assembly. This car just doesn't like me. Many thanks Marc👍 VF7**************[VIN obfuscated, can be read by forum staff]
x 6945
Here you go:
(2) Right Driveshaft
Citroen OEM New, part: 9677916180, £485.34
Exchange, part: 1609609680, £285.384
Narl
x 4
Would it be possible to get this please?
Narl wrote: 17 May 2023, 19:58
x 6945
@Narl: We don't know what you are referring to - there are no belts in the diagram. Unless you know what it is or can provide a photo, I can't help you. The 2 main belts will be the Timing Belt and the Alternator Belt.
Timing
Aux Belt
dylan26__
x 22
Unread post by dylan26__ »
Good weekend! Can you please find me the bolts that hold the Horn bracket to the vehicle? was replacing the horn and have misplaced one of the bolts.
Thank you!
