Year 2000 Xantia 3.0
Hi. I have a problem with the fan speed on my heater/aircon. No matter where I set the fan speed controller i.e Auto/Max/Off etc the fan still operates at Maximum speed. Not too much of a problem during this hot spell but it certainly is noisy. Any ideas where too start looking?
Heater Fan Speed
martyhopkirk
Resistor pack seems a likley suspect. On the other hand - try giving the little air con sensor fan next to the clock a blast out with some compressed air (if you can, remove, clean and lube it)it may be sending false messages to the control - though shouldnt think its this stranger things have been known with Xants...
- x 1238
guillermo
zzf00l
AndersDK
To put pictures here :
http://www.andyspares.com/discussionfor ... IC_ID=8459
[email protected]
- x 694
Has anyone else ever had a problem with intermitant fan speed control ? On more than one occasion on my Dad's 1994 SX and once (so far) on my 1997 VSX I've noticed a situation where the fan speed control is inoperative -
When it happened, the air conditioning was turned off (both cars have air conditioning and include an "Auto" setting on the control) and the fan was running, and then when I go to adjust the fan it won't change speed. It will be locked on whatever speed it was previously on, regardless of sliding the switch anywhere, even triggering the A/C on then off wont have an effect.
When this happened to my car for the first time yesterday I pulled off the road and fiddled with the controls to no avail. On a hunch I then turned off the ignition and turned it back on - Voila, fan speed control now responds again, all settings including auto working properly.
It seems almost as if there is a small computer that controls the fan speed, (possibly in combination with the air conditioning system especially when set to auto) and that this computer on rare occasions might "crash" leaving the fan stuck at whatever speed it was running at. Turning the key off and on must reset this controller.
There must be *some* kind of electronic controller involved in controlling the fan speed (whether just a simple electronic one, or a small computer) as (a) there is a significant delay between moving the switch and the fan speed changing, and (b) the functioning of the Auto position in tandem with the A/C.
It's probably happened on my Dad's car about 4 times in the 4 months he's had it, and happened once on mine and I've only had it a week [:D]
Anyone got any ideas ? I would have thought if it was a faulty transistor pack the fan would be permanently on, but that is not the case, after turning the ignition off and on it is back to normal again...
Regards,
Regards,
Clogzz
- x 40
http://www.andyspares.com/discussionfor ... erms=relay
Have had that problem.
The current for the heater goes through the ignition switch that can't cope with 30Amp at high speed.
The electronics under the fan get reduced voltage and they lose reference to control the speed.
The reduced voltage also causes lack of current for high speed operation.
Mine would cause total loss of speed control.
I couldn't turn the fan off...it kept spinning at reduced speed on all settings, even 'off'.
I got given a hand-drawn diagram showing the ignition switch operating a relay that took the fan supply before the ignition switch and went to the fan through a 35Amp in-line fuse.
I got told very clearly that the diagram had to be ripped up when the job was done, and I duly did that.
This job involves the removal of the steering wheel and shrouds.
I broke the top shroud mounting in the process, and glued it back in.
I made a small hole in the top shroud to insert a screwdriver to reach the top mounting screw for next time I have to go there.
It is impossible to loosen the top screw without seeing it.
zzf00l
Clogzz
- x 40
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by zzf00l</i>
Different problem I think.....If the Ign. Switch is faulty I believe it can be completely inoperative or stuck at any speed between OFF and MAX...(I think).
Ian
Yes, different fault.
Was in reply to Mandrake's post.
Ian
