Hi , can you get the build spec from somewhere from the vin ? I want to know if my car has a dual mass flywheel or not , as I am having a juddering issue once passed about 15mph , some research suggests a dual mass problem but I have know idea if it's fitted with one , it's a 90bhp diesel .
Thank you .
DS3 build spec
- x 3296
Re: DS3 build spec
Hi, and
to the Forum. it may be possible for a Moderator to get the build information from the PSA systems (although, as you surmised, they will need the VIN), but I think there were issues with getting it for the DS range (but I could be wrong).
281192ben
Re: DS3 build spec
Thank you for info , hopefully either build spec or someone might know if my car has a DMF fitted or not .
- x 6945
Re: DS3 build spec
I can advise if you have a DMF or not, (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff).
281192ben
Re: DS3 build spec
- x 6945
Re: DS3 build spec
It's showing as having a single (solid) fly wheel.
