RuiV
Hi,
Can you please give me the schematics and part numbers of the cooling system of my 5008 II?
Thank you
Thank you
- x 6945
If you require specific part numbers, let me know for which items from which Diagram
| Diag A Cooling Hoses | Diag B Outlet Tank |
| Diag C Water Pump | Diag D Expansion Tank |
| Diag E Fan | Diag F Radiator |
Huskyxantia
- x 909
My vin VF3**************[VIN obfuscated, can be read by forum staff] needing part number for front shocks many thanks
Husky.
- x 6945
(1) OEM original parts have been superseded with replacement shocks:
Part: 9810195380, £97.26
Part: 9810195480, £97.26
Cheaper Peugeot Versions:
Left: 1674698580, £83.77
Right: 1674698680, £83.77
RuiV
Can you give me the parts for diag's A, B & C, please?GiveMeABreak wrote: 25 Apr 2023, 16:24 If you require specific part numbers, let me know for which items from which Diagram
Thank ou
- x 6945
I'm only listing main parts as you haven't been specific.
Diag A:
(1) Rad Water Inlet Hose, part: 9812441880, £26.59
(2) Rad Outlet Hose, part: 9812441980, £47.78
(4) Rad Degassing Water Pipe, Part: 9677186380, £13.72
(12) Cylinder Head Degassing Pipe, part: 9812442980, £23.56
Diag B
(1) Water Outlet Tank, part: 9812113780, £181.90
(3) Water Housing Seal, part: 9813021980, £9.35
Diag C
(1) Coolant Pump, part: 9836834880, £152.87
(2) Coolant Pump, part: 1628941780, £127.34
(3) Water Intake Tank, part: 9820174380, £130.78
(8) Outlet Hose EGR, part: 1638153380, £88.79
(10) Water Pump Seal, part: 1628942180, £25.15
Diag A:
Diag B
Diag C
Huskyxantia
- x 909
Marc the rear shocks on a 207 are they the type that go through the rear wheel arch into the boot area behind the wheel arch carpet ? And whats the part number for them my vin
VF3**************[VIN obfuscated, can be read by forum staff] massive thanks
Husky.
- x 6945
(1) Rear Damper (to be replaced in pairs):
OEM replacement part: 9811403480, £94.14
Peugeot Cheaper part: 1623315080, £55.50
As for the positioning, does this help:
Huskyxantia
- x 909
Excellent, thanks Marc , cars going to be worked on today so will double check mines against the diagram. Thanks.
Husky.
Huskyxantia
- x 909
My rear brakes are drum type, would this make any difference ?GiveMeABreak wrote: 25 Apr 2023, 23:24
Husky.
Huskyxantia
- x 909
Marc is there part numbers for the engine under tray clips and bolts at all ? Diagram would be helpful peugeot 207 1.6hdi , many thanks.
Husky.
- x 6945
(80) DIAM 16 EP 2 A 4,5, part: 703016, £1.15
(81) (MUL) CLIP part: 703018, £0.28
(83) BOLT H RPL VIS HX M6X100 L20, part: 9809840080, £0.46
(84) (MUL) CLIP, part: 6986A8, £1.67
(85) (MUL) FLANGED NUT 6X100-8-10, part: 871832, £1.15
Edhertz
- x 5
Hi, Could you please supply the part number for the pump to the regulator hydraulic pipe,
Cheers, Alan
Cheers, Alan
Alan
1999 Xantia Exclusive 2.0Hdi Mauritius blue
1999 Peugeot LX 1.9D silver
- x 6945
Have a look at the following Alan, and let me know the item number of the pipe you require, (if this is the one):
Supply Piping Front Suspension
If it's (1) Hydraulic Fluid Return Harness, it is part: 5270KY, however no longer available from Citroen.
Edhertz
- x 5
Hi Marc, Thanks for reply. Looks like it's 2 I'm after,
Cheers Alan
Cheers Alan
Alan
