Rear Foglights
Chrispy
Rear Foglights
Just noticed my rear foglights don't work. I've replaced the bulbs and the fusr is ok. What else could it be? The front ones are fine.....Wierd!
jeremy
Have you got trailer lights fitted? Proper Citroen lead/socket has a nice switch in the socket which turns off the car foglights when the trailer is attached. Replace proper socket with an ordinary one and the rear foglights don't work!
Disconnect trailer wire form LH rear light and plug back together - if it now works thats the problem - cure by finding the lead and connect the foglight wirs together with a couple of scotchlocks and a length of wire.
jeremy
jeremy
Chrispy
jeremy
- x 8123
Chrispy
O/S rear light cluster.....The one inside the boot (with the brakelights) or the one in the tailgate that lifts up (where the foglight bulbs themselves are)?
The lights on the Xantia are split between those on the boot door iteself and the corner of the rear of the car so it's knowing where you mean!
Cheers for your help guys,
Chris.
Chris.
jeremy
- x 8123
Sorry, It's behind the body mounted cluster. You have to pull the side trim away to get at the plug in question. It will be found hiding just underneath a plastic lump attached to the rear inner wing. With the trim pulled sufficiently away to expose the loom running from the light cluster, you'll locate it about six inches along the loom. Very difficult to explain! Let me know if a picture would help and I'll take one.
Chrispy
