dylan26__
x 22
Unread post by dylan26__ »
GiveMeABreak wrote: 03 Apr 2023, 18:41 @dylan26__:
Item (1), Under Engine / Gearbox Sound Proofing, part: 7013GL, £310.60
Item (2) is not listed for your vehicle (that's for petrol engines).
ah okay, thank you as always
APro
Unread post by APro »
GiveMeABreak wrote: 03 Apr 2023, 18:30
APro wrote: 03 Apr 2023, 17:59 Hi there, quick request
Vehicle : Citroen C5 (X7) 2.0 HDi
VIN: VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff]
part: timing belt tensioner bolt
Let me know which item you need the part for:
That would be number 70
Thanks Marc!
x 6945
@APro
(70) MUL Flanged Bolt (DIAM 8X125-55) part: 6925W5, £2.54 from Citroen.
Huskyxantia
x 917
Unread post by Huskyxantia »
Hi marc, part numbers for as follows, its a long list
My vin VF3**************[VIN obfuscated, can be read by forum staff]
Front brake discs & pads
Rear brake drums & shoes & fixing kits
Hand brake cables.
Remote flip fob case ?
Not needed but for reference DPF.
Front & rear wheel bearings.
Many thanks.
:-D
x 6945
VIN is incorrect Husky. It's 16 long and should be 17.
Huskyxantia
x 917
Think it has a 9 on the end VF3**************[VIN obfuscated, can be read by forum staff]
:-D
x 6945
Front Disc Kit
OEM part: 1647868480, £195.65
Cheaper part: 1686717180, £62.71
Front Pads
OEM, part: 1646186180, £104.22
Cheaper part: 1617282980, £29.51
Rear Brake
Rear Brake Hub & Drum Part: 424750, £249.29
Hub Nut, part: 373932, £12.56
Hub Plug, part: 374046, £5.59
Set of 4 Rear Brake Shoes
OEM part: 4241N3, £171.20
4 shoe pre-fit brake kit
OEM part: 424244, £227.18
Cheaper part: 1611451680, £184.91
Hand brake cables
Secondary Brake Cable
OEM part: 4745Z3, £75.55
Cheaper part: E074178, £31.80
Remote fob transmitter
With key cut to vehicle, part: 649034, £174.08
With Raw key (uncut), part: 649075, £146.06
Particle Filter
OEM part: 9803421880, £1163.58
Exchange part: 1609532780, £726.31
Front Stub Axle Carrier
Left part: 364690, £375.56
Right part: 364790, £364.97
Rear Wheel Hub Bearing
OEM part: 374890, £88.21
Cheaper part: 1681930580, £29.84
Huskyxantia
x 917
Many thanks marc, is there a part number for the gear box oil seals ? I want near side one. Would ep80 or 90 oil be ok ? Thanks
:-D
x 6945
Oil is listed as FE 75W.
You'll need to be more specific regarding what specific 'seal' you want, as I can only reference a lip seal or o rings on the tachometer control screw.
(9) Gearbox Lip Seal (40X58-10), part: 1623179580
Huskyxantia
x 917
Hi marc, ive just known them as what ive put , its the passenger side drive shaft location into the box , would they be called drive shaft oil seal ? Part number 9 looks like it may be the part only someone who has had the car before had a new clutch & just popped the drive shaft straight back same seal used .
:-D
x 6945
This perhaps?
(6) Gearbox Primary Shaft Seal, part: 210940
Rhothgar
(Donor 2026)
x 221
Unread post by Rhothgar »
Evening Marc,
Hope you've had a great Easter weekend.
I hope posted a request on my HDi Leak Stupid Question post rather than here as you wanted it moved. Is there any possibility that you could provide the information requested at some point during the course of this week please? I've asked for the rear suspension fiche too and will need the same data of that ie part numbers, lengths and diameters. I am trying to work out the full length of coils I will need to renew ALL piping on the Xantia.
Thanks in advance.
I had no idea of how to tag you so just quoted a link hoping you would see it.
Huskyxantia
x 917
Marc is there part numbers for the clips & bolts that secure the engine under tray on the 207 , mine have rusted that much they can't be reused its for my 207 1.6hdi. Thank you.
:-D
Huskyxantia
x 917
GiveMeABreak wrote: 09 Apr 2023, 15:54 This perhaps?
Thanks Marc, ive got a full kit on order .
:-D
Orbit Motors
x 19
Unread post by Orbit Motors »
Good morning, after a couple of bits for the C6.
I have a knocking on the offside front which I have traced to what would appear to be the inner tie bar, but the joint is behind a rubber boot. Any diagrams and numbers relating to the tie rods and how they attach to the rack would be most appreciated.
Also something slightly obscure, the block that the brake pad wear sensor wires plug into. Seems to be the same plug sizes as other PSA stuff and probably not something searched often but one of mine is toast.
Many thanks
Cheers,
Miles
Satisfaction guaranteed or your dent back!
If it just about starts and drives, I'll probably buy it.
1995 Peugeot 306 XLd
2007 Citroën C6 Lignage
2003 Saab 9-5 3.0 V6 TiD
