blown fuses
john alexander
blown fuses
Unread post by john alexander »
Hi I need some quick help ,I need my xanti 1.9td on friday and can't find my BOL .It blows fuse 28. indicators,rear wipe, as soon as it is replaced it blows again before I switch anything on. By the way the hazards work OK. Thanks john.
x 1238
Unread post by Peter.N. »
Could be the leads from the body to the tailgate, pull the rubber boot back and inspect them.
x 1044
Unread post by wheeler »
is it an estate by any chance ? my bet is a siezed/shorting rear wiper motor.just unplug it & see if it stops blowing fuses,if it does stop you know its the motor.
john alexander
Hi wheeler its an estate and i've just read your post after coming in from unplugging the rear wiper ,will have a better look later. regards john
